whistle from my exhaust
  • pepsi_coke
    • 288
    I have a 93 GTP (3.4L TDC/5spd) .. I have been hearing this weird noise coming out of my exhaust .. when I turn off my car. It lasts a couple of minutes. And it sounds like air is being pushed through the exhaust. No idea what it is, anyone have this happend or know what possibly it could be?
    Thanks
    New member of 200,000 mile club as of May 16, 2005
  • dykz34
    • Jan 2004
    • 793
    Could be the AIR injection that the 5spd cars got.... mine doesn't work so I don't know what it sounds like.
    • Rhedalert
      Dr. Feelgood
      • 1574
      The whistle go WOOOOOOOOOOOOO!!!!
      Brian
      3400 SFI V6, 4T60e
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Could be those pesky little elves on their way to work. ( I kill me! ) But I would guess something else. Do you shut your car off in gear?
        • pepsi_coke
          • 288
          Yeah, I park it in reverse and sometimes in a forward gear (1st or 2nd). Someone had mention something about valves were turned off while still in motion and Im leaking through my rings. Does that make sense to anyone.
          Oh yeah, and my Smog Pump (AIR PUMP) is a POS and needs to be replaced. Anyone got one for sale ?
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            Originally posted by pepsi_coke
            Yeah, I park it in reverse. Someone had mention something about valves were turned off while still in motion and Im leaking through my rings. Does that make sense to anyone.
            You have latent combustion leaking out. Remember, the engine is hot and any cylinder that is closed will pick up some combustion. It is normal. Automatics don't do it. It is the engine just getting rid of pent up combustion. You can stop it by putting the park brake on and leaving it in neutral. Had to edit this.... Not from your rings. Combustion leaking through rings goes into oil pan. Leaky exhaust valves whistle.
