gasket/idle question
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    when replacing the plenum, tb neck and tb gaskets on a 96 intake, should I use any liquid gasket or rtv to get a seal?
    next when i start my car it idles up to about 3-3500k and then dies any suggestions on the cause? (no codes from the scanner either)
  • dykz34
    • Jan 2004
    • 793
    You shouldn't have to use anything except the gaskets...
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      ok just making sure on the gaskets. a little more info on the idle the tps seems normal, the IAC reads 90 steps when ign is on and 134 while it runs briefly be4 it dies.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        Update: i found the problem it was a leak in the egr adapter tube.
        it idles smooth but it gives a code now p1650 failure QDM2
        the only thing i can think of is since the egr is bypassed for now could that be the cause of the code?
        i hooked up the solenoid but it still gives the code. can the ecm detect whether or not the plenum is recieving exhaust gasses via o2 sensor readings?
        • bud36light
          • Nov 2003
          • 517
          hmmmm. Just wondering where the leak in/on the tube was?
          2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            it was a fix where the tube was cracked near the adapter plate. i looked at the boneyard today but no luck for a replacement. i checked the dealer 85 bucks fuck that.
            • dykz34
              • Jan 2004
              • 793
              JB Weld.
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                the code is caused when i unplug the egr solenoid. when i fool the pcm into think egr is there when it is not it will spark knock for a few and even out to a smooth idle.
                when i disconnect it the code comes up and the idle changes around. machine shop has it again when it gets back i will be straight. got my wires in too so i will take care of that sun or mon.
