oil pumps
  • Anonymous
    Originally posted by Zboy
    Unless there is a problem with the stock pump not keeping up with the oiling needs of the engine
    There is on a 3.4L. It may not be the pump itself, maybe more oil volume will help it not dry out the bearings, but we will see.
    • dykz34
      • Jan 2004
      • 793
      I don't think there is a problem with the stock pump on the DOHC... I think yours was a fluke. I've, personally, never heard of another causing the same problem you had. Blanket statements are teh devil@!
      • v6h.o.
        • 1418
        I agree.
        Colin
        • Anonymous
          Now if I was to run to 8k, spinning the pump that much faster, putting that much more oil to the top side, but also having a quart more to draw from, I do not think I will have any problems. You seem to think that the 3.4 pump is adaquate, which it may be. When i get time to pull this damn motor apart, I am going to see how much different the 660 pumps are from the SBC/N*.
