screw that noise. remove the plenum, remove the retaining clip from the dist block, pull it up until it hits the head, use some liquid gasket, make a bead, work it in, let it set, put the retaining clip back on, put the plenum back on and you are good to go. no grinding of the head needed.
replacing the infamous "o-ring"
So..do you have to reset the distributor timing afterwards?
I'm gonna do mine today, I'm getting tired of changing the carpet under my car. Time to change the plenum gasket anyway. I will do it Dohcfiends way, probably use CopperBond Sealant and for added measure, a Chevy dist. gasket.
uhh, the timing is automatically set by the ICM/ECM, these cars don't have a distributor.
Or is that just a joke?
'93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
'06 Dodge Magnum SXT 3.5L -- My Daily Driver
Can someone please email me the pics at papiton69@yahoo.com ?
I am about to do my lower gaskets and might as well fix the dang oil leak too..
thanks
I never joke...Originally posted by 93Oldsdroptopuhh, the timing is automatically set by the ICM/ECM, these cars don't have a distributor.
Job went perfect..After the plenum is off and the retainer off, I simply tied a piece of 2 lb test fishing line around that critter to hold it up a bit, cut the Chevy distributor gasket and slid it under. Used a Q-Tip to work the CopperBond on both sides of the gasket. Cut the line after about 15 minutes and put it back together. No more does my car mark it's parking spot. Complete job cost 45 bucks and took 2 hours. (Shoulda been 20 bucks and 45 minutes, but there was beer involved.)
bad o-ring leads to oil on ground or oil burned in engine?\'97 Monte Carlo Z34- Milzy Motorsports 2\" Headers, 2.5\" Mandrel Exhuast, Ported & Polished Upper & Lower Intakes, Ported Intermediate Arm, NGK TR55\'s, DHP PCM, 180* T-stat, EGR Delete, GM STB, GMPP Trailing Arms, & Coldz CAI w/ K&N cone.
i think i have bad valve guides then, the car usually smells like its burning oil when its cold, but goes away when it warms up... stinky shit\'97 Monte Carlo Z34- Milzy Motorsports 2\" Headers, 2.5\" Mandrel Exhuast, Ported & Polished Upper & Lower Intakes, Ported Intermediate Arm, NGK TR55\'s, DHP PCM, 180* T-stat, EGR Delete, GM STB, GMPP Trailing Arms, & Coldz CAI w/ K&N cone.
hey, i'm in the middle of this job right now i got a few questions about it.
namely i do not want to cut the head because the tang above the dist drive has a mounting hole for the lower intake and i don't want to risk coolant leaks, however i have the new O ring from the dealer, could i grind abit off the top of the pump drive itself and streatch the ring over it and put it down in the hole that way? then mabie use silicone and use that to seal it for good measue?
also could i be leaking oil from the block off plate where the pushrods would go?-Chris
1992 Chevrolet Lumina Z34 3.4L TDC Getrag 284
1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
1997 Pontiac Bonneville SSE 3.8L v6, Hydramatic 4T60E
1987 Chevrolet Camaro 5.0L v8, Hydramatic 700R4
I would say that you are likely dealing with bad/worn valve stem seals. My car was as you describe when I first bought it. I could smell oil burning when cold but could not see it. When I tore down the enigine I found several valve stem seals had broken retainer springs and were riding freely up and down on the valve stems.Originally posted by 97montez34i think i have bad valve guides then, the car usually smells like its burning oil when its cold, but goes away when it warms up... stinky shit
Needless to say a nice new set of seals fixed it.
