Water Pump
  • Toofastgtp
    • Oct 2004
    • 57
    Water Pump
    Ok got a 94 GTP 3.4L.......80k miles for 2k
    now i need to know how hard the water pump is gonan be to replace....liek do i gotta remove crap like my 3.8 i have to remove the powersteering pump.....
    i keep on adding water and it goes out the water pump area.....car still needs work but hey 2k for a 80k mile car
    -2000 GTP - 332/426
    -94 GTP - Stock, But needs new:
    Door, Steeringwheel, fender, windshield and window for new door, and power steering line.
  • goatman
    • Jun 2004
    • 151
    Does the GTP have the coolant reservoir on the passenger side of the engine bay? If so, you will need to remove this, just one bolt and one nut, both 10mm. Then an 18mm whench on the belt tensioner to get the serpentine off. The water pump is the one closest to the radiator, right under the front cam carrier. Four 10mm bolts to remove the pulley. You may need to get a little creative with a screw driver or similar to get them all out, or you could prolly leave the belt on until they are loose. (Otherwise the pulley will turn, and you'll get pissed off) Then its like 5-7 bolts, either 10 or 13mm to get the pump out, then just put the new one in. Be sure you use water pump sealer, smear some on both the pump housing and the block, but dont get it into the coolant passages.
    1993 Lumina Z34 - Broke Yet Again
    What the flip Uncle Rico!?!
    • Toofastgtp
      • Oct 2004
      • 57
      sweet....so are all the bolts easy to get too?
      -2000 GTP - 332/426
      • goatman
        • Jun 2004
        • 151
        Easy enough, you might need to feel around for the ones on the bottom of the pump, but its fairly straight forward.
        • goatman
          • Jun 2004
          • 151
          Yea, there are 5 bolts, all 10mm. My motor is out of my car right now, so I just went out and made sure. There is a flywheel that the pulley bolts to, you'll need to feel around under it, but the whole job shouldn't take more than an hour, start to finish. You'll want to have a pan underneath the car to catch the coolant, and then of course add new to make up for what came out.
          • Toofastgtp
            • Oct 2004
            • 57
            sweet thanks alot
            -2000 GTP - 332/426
