MAP Sensor location???
  • Vetter
    • Dec 2004
    • 17
    OK, dumb question, but I just bought a new MAP sensor to replace my old one on a 94 GTP. But I can't find it's location :P
    Where the heck is this thing??????????
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Should be on your firewall, has a vaccum line connected to it. And some wires. Upper right photo....
    • Vetter
      • Dec 2004
      • 17
      This is Wierd, because I don't have one on the firewall. I have the 3.4, is it possible they put it in a different location? I even removed the plenum last night, thinking it may be under it, with the fuel pressure regulator.
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        94 DOHC has MAF, not MAP. My bad, I should have read closer....
        • Juglenaut
          • 1130
          pre 94 has a MAP mounted on the side of the plenum by the power steering pump.
          I am back
          Mechanical/Service Technican
          • Vetter
            • Dec 2004
            • 17
            I don't think I have the MAF, because I have a IAT in the intake tube.
            I don't have anything by the power steering pump. I'm beginning to wonder, if maybe someone has cut the MAP out, I will look for cut wires tonight. I just bought the car.
            • WhiteMonteZZZ
              • Dec 2004
              • 41
              I have an IAT in the intake tube too....and a MAF sensor between airbox and intake tube.....and I think my 95 has a MAP sensor AND MAF sensor if i recall correctly....my GM service manual makes not of it but the manual isn't handy right now...
              1995 Monte Carlo Z34 - 3.4L
              1980 Trans Am - 6.6L 400, 428 heads
              • Vetter
                • Dec 2004
                • 17
                I do have a MAF, and also the IAT.
                Shouldn't I have a MAP also? Or did 94 not have a MAP?
