300 buxs to read code at autzone
  • Toofastgtp
    • Oct 2004
    • 57
    WTF.....
    There machine can only read OBD II
    They said i have to buy there 200 buxs code reader than another 100 for the gm cartrige for it.
    Cant use the paper clip trick cus i got a 94, my 94 only has 3 wires in the asdl port....
    Black, Green, Tan.
    WTF
    -2000 GTP - 332/426
    -94 GTP - Stock, But needs new:
    Door, Steeringwheel, fender, windshield and window for new door, and power steering line.
  • DreX
    • Nov 2003
    • 74
    RE: 300 buxs to read code at autzone
    Do your self a favor. This will help you with the codes. http://www.w-body.com/ecm-codes.html
    Now you can buy me a beer with the money.
    Hope helped.
    Dre
    • Toofastgtp
      • Oct 2004
      • 57
      like i said the paper clip trick does not work.....
      i got a 94 with obd 1.5..
      i dont have the B port........i got the 3 wire asdl port
      Ground, 5volt, and a tan wire
      -2000 GTP - 332/426
      • Vetter
        • Dec 2004
        • 17
        Go to Advanced Auto, they read my 94, after a few guys said they couldn't, another more informed guy did it.
        Autozone probably can, but they have a bunch of boneheads working for them, none are informed. I had a guy in Autozone argue with me, telling me my car had two O2 sensors, when I said I know for a fact only one is on my car, he insisted someone had to of removed it! :P
        • Toofastgtp
          • Oct 2004
          • 57
          advance auto is autozone in oklahoma.....and there machine only checks obd 2
          -2000 GTP - 332/426
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            Vetter is absolutely right. Just called Advance, just to check, They said "No Problem".... A-Zone is for Rice, and Old fellers. They don't even stock my spark plugs. (NAPA is the best though as far as chain stores go) I use "Undercar Specialty" They rock. And know their S..t. www.undercarspecialty.com But it is a Dayton thing.
            • Toofastgtp
              • Oct 2004
              • 57
              only places is autozone, pepboys, napa, and oriellys..
              Autzone is the only ones that carry code readers and can read codes...all they do again is obdII
              -2000 GTP - 332/426
              • LakeFXGP96
                • Feb 2004
                • 50
                pep boys here in Kzoo will ready codes for free, and have simplistic code readers, cant remember price though. Hell for $300 you could buy or use toward a snap-on scanner or an older tech II with cartridges on ebay and scan just about anything with a steering wheel, and those will even tell you how to fix it!
                Daily - 1993 Lumina Z34 - Rebuilt 3.4. Restoration in progress.
                Fun -- 1996 Grand Prix SE B4U w/L67 swap - 13.851@99.29 3.4, PEMs, DHP, Exhaust, CAI and a bunch of minor mods.
                • fieromadman
                  3.4 DOHC fiend.
                  • Feb 2004
                  • 130
                  94-95's use all OBD2 terms on thier codes, it will work on OBDII scanners more than likely.
                  3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
                  1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
                  • LQ1
                    • Apr 2004
                    • 151
                    Autozone has no problem reading my 94
                    www.cardomain.com/id/topless94style
