when i got that light i ripped off my egr valve and took it apart and cleaned it and i cleaned out the intake too and then i sealed the gaskets with hi-temp copper silicone gasket maker and it worked fine. usually when you get that light they are just dirty and need to be cleaned.
Error Code 32???
Cool....
Well im going to try to clean it first. Hopefully that does the trick. I'm thinking it is just dirty. It seems to only be doing it now whenever I get a fill up. I always run super. But accidently ran cheap gas this last time. I'm thinking that may be whats causing it. Anyways i'm going to go ahead and pull it off today. Also going to remove the intake cause i got a deal on a set of Accel Injectors. Summit has a sale going on them. It has to be dirty cause SES is not on all the time. Or theres a bad injector causing it. Well see...
\'91 Chevy Lumina Z34
Soon to do a 3.8L Series 2 Swap
4T60E 4 speed Auto
K&N air filter
White/Gray interior
It's possible you could... I was reading a post on here somewhere. A guy fixed his son's 3.1L. And they replaced the EGR,IAT all the vacum lines. Bought a new set of injectors and solved the whole problem. Anyways cleaned the EGR and passage on mine. Seems to be alright. I'm going to put new plugs and high output injectors. Get rid of these GM ones. Replacing with Accel Bosch style. Should be pretty cool. Not sure what plugs im gonna run yet. Probably Splitfire.\'91 Chevy Lumina Z34
4T60E 4 speed Auto
K&N air filter
White/Gray interior
look at my cardomain..there is alot of stuff on the egr on page 3 i think. i have how to test it, clean it, and tear it apart
1st 04 GPG 88-96 mod car show
L67 Swap, 3.25, XP'd, Custom Headers, 180 tstat, AL103's, 7" K+N, AFC2.2, Rat UDWP & Alt, Walbro,Taylor wires
N* TB & HP Ported Blower
PB-13.3@102mph
http://www.SleeperSe.com
http://wbodysource.com
thanks..that is why i did it, lol
PB-13.3@102mph
