humming noise coming from trunk area
  • tony94gtp
    • Jan 2005
    • 34
    i hear a humming noise coming from my trunk, what could it be ? i have no electronics back there. wondering if it could be the in tank fuel pump ? has anyone had this problem? and is it a problem? what was done to fix it?
  • pepsi_coke
    • 288
    When do you hear the noise? When driving? When you first turn key to "ON" position? ONly when braking? accelerating? Idle?
    New member of 200,000 mile club as of May 16, 2005
    • Lyle's GTP
      • Jan 2004
      • 1345
      Fuel pump fucking up?
      Lyle
      • MIGUEL
        • Feb 2005
        • 4
        humming
        A couple possibilities if it is when the car is running, fuel pump malfunctioning. A hole in your exaust that could be below your fuel tank and or spare tire trunk compartment. The sound could resonate causing parts to vibrate, causing the hum within your trunk.
        • RollinonZ34
          • Jan 2005
          • 79
          Do you have the Stock Bose Amp mounted inside top of trunk? Some do and some don't if you don't have the Stock Bose sound system.
          94 Lumina Z34
          Moved Wife & Kids Out So I Could Have More Room To Park Z34 In Livingroom.
          • Juglenaut
            • 1130
            Worn Hub bearings can hum.
            I am back
            Mechanical/Service Technican
            • PlatinumZ34
              • 232
              mine hums also. (well it did back when the trunk closed) I had the bose amp, and it stopped when i pushed the trunk down. I just assumed it was some sort of pressurization thing. Air leaking out of the trunk or something...
              2001 Mustang GT
              1991 5spd Lumina Z34 - Dead
              1947 4spd International - Dead... Reincarnation pending.. getting close now .
