Removing throttle plate bearings
  • sspeedstreet
    • 282
    Like the title says . . . I want to powder coat the upper intake on my 1992 motor. I've removed the swaged spots and they're still not moving. Anyone here ever get them out?
  • XLR8ING
    Too Stupid To Quit!
    • 268
    Once you grind off the "nibs" that hold the bearings in, you can take a 1/4" socket extension and gently tap on the bearings from the inside of the TB to get them out.
    Work in a circular motion as much as you can, though with the TB getting in the way, it's hard to do evenly.
    I've only done this on the 3100, 3400, and 2.4L throttlebodies, but those have all been the same.
    Franz
    1990 Z24-NA 3.1L
    14.72 @ 92.24 MPH
    14.89 @ 94.92 MPH
    The boost is coming....
    • sspeedstreet
      • 282
      Kind of what I had in mind when I started this project. Problem is, the hole in the throttle body for the shaft to pass through is very close to the diameter of the shaft itself.
      Any ideas?
      • XLR8ING
        Too Stupid To Quit!
        • 268
        I put the socket extension in from the back of the TB butterfly hole and tap on the bearing on an angle. It's the only way I've figured how to do it.
        Good luck man!
        Franz
        1990 Z24-NA 3.1L
        14.72 @ 92.24 MPH
        14.89 @ 94.92 MPH
        • sspeedstreet
          • 282
          Do you think heating the t/b housing would help?
          • XLR8ING
            Too Stupid To Quit!
            • 268
            Possibly, but I'd almost think the bearings would expand more because the aluminum housing would dissipate heat faster than the steel of the outer bearing surfaces.
            Franz
            1990 Z24-NA 3.1L
            14.72 @ 92.24 MPH
            14.89 @ 94.92 MPH
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              Make a simple slide hammer out of 1/4" all thread. Or..Use the all thread to draw it out. Put large washers on the outside and support the inside with smaller washers. I used the slide hammer on mine. Remember to stake it when you reinstall. Don't heat! Aluminum hates that..
