How do you remove the inner door panels? I did a search and nothing came up. I thought I saw something on here about how to but I forgot where I seen it @. thanks
How do you remove the door panel?
RE: How do you remove the door panel?
Remove all screws from the perimeter of the panel. Then remove the courtesy light cover, then the light housing. Their will be a screw behind that. Next pop up the plastic piece behind the seat belt. Then remove the screw from behind that. Next behind the door handle their is a small plate, undo the screw from there then their (should ) be another screw behind it. Then the last screw is under the door pull handle. It is located near the front and goes up at an angle, it's a torx if I remember correctly. Next remove the plate that holds the window switches, you will need to unplug those. While you are at it check for anymore screws under their, I'm not sure if their is any or not. But I think thats it. The rest are plastic push fasteners, they may break when you pull them, you can use a tool if you have one.
I think that's right, if anybody has anything to add please do.
Lyle
