while hooking up the neons i found the fuel filter(which i have a new one ready to go) and what would i need to do to replace it? O2; will taking the plenum off make it more easier to get to it? thanks!
fuel filter & O2
fuel filter & O2
http://www.w-body.com/forum/viewtopic.php?t=24111
Car Domain site!
13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!Tags: None
RE: fuel filter & O2
for the fuel filter i think one side is a quick disconnect and the other side is a nut u off to undo.. make sure u release fuel pressure before removing it or your going to get some fuel spray... the o2 can be reached easier with the intermediate arm, and the upper intake off. it'll probably be on there pretty good if your car has high milage and its never been removed. i think the O2 new was $84 or something, the fuel filter should be $10-15 from a parts counter if not lower\'97 Monte Carlo Z34- Milzy Motorsports 2\" Headers, 2.5\" Mandrel Exhuast, Ported & Polished Upper & Lower Intakes, Ported Intermediate Arm, NGK TR55\'s, DHP PCM, 180* T-stat, EGR Delete, GM STB, GMPP Trailing Arms, & Coldz CAI w/ K&N cone.
got both parts, $6.99 for the filter and like the same for the O2.http://www.w-body.com/forum/viewtopic.php?t=24111
Car Domain site!
