'94 GTP - Trouble Codes
  • Makman
    • Feb 2005
    • 5
    Thought I previously found an explanation and listing of the diagnostic trouble codes for this car. Seems to have OBDII type plug, but with OBDI diagnostics (obviously), and only 3 pins in the connector (which don't match up with the generic code readers - special pattern, apparently). The post I remember reading talked about the "old" way to extract the codes (paper clip, and "service engine" light flashes - like some imports I've worked on), and had a link to a web-page with the full code listings and even a picture of the connector pins and bridging location. Can any of you kindly help with this? Finally getting close with this car, but this information would really help. Thanks.
  • Makman
    • Feb 2005
    • 5
    94 GTP - Diagnostic Codes
    Found what I was looking for in another place. Maybe this will help somebody else. The site below's not bad for some things, but you'll have to enable pop-ups, if you have a blocker on your browser. Let me know what you think - appreciate any other help, especially with a prior post.
    Website - http://autorepair.about.com/library/...l-dtcs-53a.htm
    Thanks again.
