injectors
  • tony94gtp
    • Jan 2005
    • 34
    injectors
    can someone explaine how to do the injector test ? thanks i have a fuel pressure problem just trying to cover all bases. pressure not holding after key is turn on and pump runs for 2 seconds 40psi then drops to 0psi hard to start after sitting. thanks for any input
  • Synestral
    • Mar 2005
    • 53
    I just replied to your pm about the injector test. The regulator checked out? If that's the case then it sounds like you've got at least 1 leaky injector. Would also explain the hard starting: too much fuel in the intake won't let enough oxygen in for combustion.
    92 Lumina Z34
    Found coolant in the oil and metal in the filter.
    Also found a home in the engine compartment for a turbo and intercooler
    Some pics at CarDomain
