oil leak
  • Dave96z34
    • Apr 2005
    • 624
    oil leak
    I'm finding oil burning on the header heat shield on the front of the motor. I cant seem to find were its coming from. Does anyone have this same problem and no's how to fix it.
  • Lyle's GTP
    • Jan 2004
    • 1345
    RE: oil leak
    Probably the cam carrier gasket. Or, (if you are lucky) the cam cover gasket.
    Maybe check your PVC valve. If it is plugged, it may cause more pressure build up in the crank case allowing oil to be pushed passed the gasket easier. (A stretch, but maybe)
    Lyle
