97 EGR valve Question
  • your_I.D.
    • Mar 2005
    • 337
    Anyone have a 97 egr valve handy. Need to check the actual plunger in the valve. Mine's loose and easy to push in. Like it only has a light spring holding it seated. This normal?
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
  • 93RegalGS
    • Apr 2004
    • 20
    RE: 97 EGR valve Question
    Yes, that is normal. It's when the plunger is hard to move is there a problem.
    -Sean
    99 Regal GS L67 / 4T65E-HD
    91 Cutlass Supreme International - 3.4 DOHC/ 5 Speed - SOLD - I still love LQ1s!
    • your_I.D.
      • Mar 2005
      • 337
      Thanks. I put it back on and assumed it was. Car was running fine. I've been out of the automotive profession about 6 years and out of the tune up/driveability side of it about 8 years. My memory is a little sooted up from working on Kenworth's w/Cummin's diesel power plants.
