Sensor on Front Head?
  • Jazic3.4
    • May 2005
    • 29
    I have the 3.4 out of the car and completely apart. There is a sensor coming out the side of the front head. I think this is an oil pressure sensor? can someone please verfiy this? I would like to put in an oil pressure gauge, so I'm hopeing this is an oil pressure sensor.
  • BlueShift
    • Jan 2005
    • 48
    Coolant temperature sensor. Green wire, right? Yeah that's the CTS which I think works the cluster gauge, while the 2 wire CTS in the lower intake manifold is what the computer reads and uses to make fueling decisions.
    Oil pressure sender is riiiiight on top of the oil cooler - you can't miss it. If you dont have one, it's probably right next to or on top of the oil filter.
    • pepsi_coke
      • 288
      Huh? Then what would the sensor be underneath the TPS and IAC, located on same harness?
      New member of 200,000 mile club as of May 16, 2005
      • series8217
        • Dec 2004
        • 387
        The one in the LIM? That's the coolant temperature sensor. The one on the head is for the temp gauge, the one in the LIM is for the computer..
