93 Lumina z34????
  • crazycrak
    • Jun 2005
    • 2
    93 Lumina z34????
    I looking in to buying a 93 z34 the outside of the car is perfect and so is the inside. but the woman said the motor was knocking its only got a 111,506 miles what could it be ??? shes asking 500 for the car is it worth a little motor work even if it could be somthing major
  • 93Oldsdroptop
    • 167
    RE: 93 Lumina z34????
    A knock is never good. Depends where it's coming from on what it is. If it sounds like lower end probably a main bearing. If you really want one and it is very clean, I'd say go for it, especially only 500 bux.
    '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
    '06 Dodge Magnum SXT 3.5L -- My Daily Driver
    • crazycrak
      • Jun 2005
      • 2
      anything else besides the buttom end ????
      i really dont wanna pull the motor
      • Rabbi
        • Jun 2005
        • 110
        RUN LIKE HELL
        do not buy it
        • eric305tpi
          • Jul 2004
          • 4
          If it is clean I would snatch it up instantly for $500. Depending on what it is it may or may not be expensive.
          • perfimage
            • 58
            No doubt...for $500 if it is as clean as you indicate, and the engine is toast. You can get far more than your $500 back by parting it out. If you have the time and space for it.
            RED
            • Dave96z34
              • Apr 2005
              • 624
              Originally posted by Rabbi
              RUN LIKE HELL
              do not buy it
              what he said
              • Dave
                • Nov 2003
                • 222
                I'd say at $500, that's fairly good, pull the motor/trans, and build it up, and mate a manual trans to it, and you'd have an awesome fun car!
                --Dave.
                Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
                • 5speedz34
                  • 301
                  Yeah, the 5-speeds are completely different animals compared to the autos.
                  For $500 you can make your money back or put in a new motor if you want to do the swap.
                  • JasonZ34
                    • 116
                    Yeah I say only invest the 500 if you plan on swapping the engine and the body would have to be prestine condition. Otherwise... drive it and listen. She may be stupid and actually be hearing the valves tick. Which seems to be normal. Listen to the exhaust too if it sounds irregular then yeah... run or plan on doing a swap.
                    • Test4echo
                      • Jun 2004
                      • 40
                      Re: 93 Lumina z34????
                      You wouldn't happen to live in Windsor Ontario would you?
