leaky injectors??
  • birdman
    • May 2005
    • 274
    leaky injectors??
    ive been tryimg to solve an ongoing problem and am having diffuicult time. I have a rough idle 1/2 the time and the exhaust smells rich so its leading me to belive that i have leaky/dirty injectors. is there anything else that could cause those symptoms? ive replaced the air filter,plugs,wires,coils,iac,tps, and icm. someone i know said that i should try some injector cleaner called techron?? any ideas?
    92 Lumina euro 3.4 DOHC 139,XXX miles
  • stantmann
    • 81
    RE: leaky injectors??
    I have at least one leaking injector now. Whenever I let the car sit for a couple hours, it starts and will idle rough, and usually will die. Typically, I rev the engine at 4000 rpm's for about 10 seconds, and after a few seconds it will settle down. Doesn't matter if it is hot or cold, it's always the same. One day I will get down there and replace the o-rings, and if necessary all the injectors.
    I would think you don't have leaky fuel injectors, but probably a vacuum leak somewhere - Listen for it. If not a vacuum leak, then one would think the IAC, but you've tried that. Check the obvious- A clogged pcv valve. A friend of mine had the same problem, and replaced the pcv, egr, iac, and it ended up being one fuel injector. How do you diagnose just one injector without taking them out one at a time? I would suggest Ebay, and get all six for the price of one!
    Stan
    1994 White Cutlass Supreme Convertible 3.4 DOHC
    Add Ons: Overhead Display, Digital Dash, Trip Computer
    • your_I.D.
      • Mar 2005
      • 337
      after the car has set for an hour or so. Pull the vacuum line off the fuel pressure regulator. If there is gas its bad. That will causing you symptom.
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      • birdman
        • May 2005
        • 274
        every once and a while i have to rev it when i start it to clear it out but ill check and see if its the fpr or pcv. thanks.
        • your_I.D.
          • Mar 2005
          • 337
          Did you check fuel pressure regulator vacuum line?
