more oil pressure
  • d.o.h.c
    • Jun 2004
    • 981
    more oil pressure
    Ok so I am putting my engine back together and tonight we checked side to side clearance for the rod to crank. on two of the cylinder the measurment was out of tolerance. now my question how to get more oil pressure. i am going to have a high flow pump and stiffer spring. and i am going to replace the two rods. also i am running a turbo on the engine. so i need more oil pressure. what can i do.
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    If you are saying your rod bearing clearance is out of tolerance, check the rod journal for sizing and out of round. If either one of those is bad, you only have 1 choice. Crank and bearings.
    • donk_316
      • Mar 2004
      • 427
      High flow pump on a dohc? Hope you increased your pan capacity especially with a turbo.
      1984 Indy Fiero 3.4L
      13.7 sec @ 98 mph
      *ALL THROTTLE AND NO BOTTLE*
      • d.o.h.c
        • Jun 2004
        • 981
        well the pump is high flow stock. i am just getting a new one and blueprinting it.
