idle surge when coasting at low speeds
  • Jewelnohio
    • Apr 2004
    • 11
    92 Cutlass Supreme 3.4 dohc . engine 199k miles xmission 100k miles. Engine starts and idles fine .Runs at highway speed ok . Shows egr code when letting off gas at highway speeds but has done that for 5 or 6 years and never had any problems before . When driving at low speed around 25 mph and let off gas , idle surges up and down approx. 1000 rpm for 3 or 4 times then returns to normal . Doesn`t do this all the time . Any ideas what is causing this ? Thanks for any Help
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    maybe your egr has a leak to the outside air.
    • Syn
      The Master Piece
      • Oct 2005
      • 599
      yeah possible vaccum leak
      • z34phoenix
        • Jun 2005
        • 469
        yeah if the egr is leaking or failing it will mess with it.... but that much of a shift in RPM makes me think intake leak... maybe thru the EGR Like said above.
