92 Z34 rack cooler lines
  • Jazic3.4
    • May 2005
    • 29
    I have to replace the longest pressure cooler line which is located right on the rack itself. I can see both ends but I can't fit a flare wrench on either end because there isn't any room. The manual says to unhook the intermediate shft bolt, both tie rod ends, and lower the subframe 3 inches.
    Can I lower the subframe 3 inches without unhooking the tie rods and intermediate bolt?
  • patgizz
    The Plaid Bandit
    • 1071
    you can lower the subframe without removing the tie rods. i've done it without removing the intermediate shaft bolt but it only comes down so far(not 3 inches, more like an inch) because the collapsible intermediate shaft is so short to begin with.
