Car runs 5 minutes then dies...*white smoke*
  • grandprix34
    • 168
    The car starts fine and runs for about 5 minutes before it starts to stutter and begins to stall. I can start the car up fine right after it dies, but it takes less time for the car to act ghey. Replaced the IAC wit no luck, car still running dumb....
    I have replaced the ALt cuz it was bad and also the ICM cuz it checked out bad too. I did not put one bolt on one of the coils since i dropped it somewhere into the great abyss but i seriously doubt one bolt missing on one coil will affect it that much...
    I just barely noticed all the white smoking coming out of the exahust...it does not smell sweet cuz most of it is water and after like 1 minute of running the fans come on *ffp chip* and coolant starts dripping out of the filler cap
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
  • grandprix34
    • 168
    DOWN WIT BLOWN HEADGASKET!!
    - Hi-Flo Cat
    • grandprix34
      • 168
      changed ECM, that is NOT the issue!! i got the car back but i dont know wat it is!?! Please someone help!
      List of things changed:
      -IAC
      -Ign. module
      -ECM
      -Fuel pump
      running out of $$ and time...not working in about a week, bye bye car
      - Hi-Flo Cat
      • pontiac92gp
        • 119
        I'd check oil and replace radiator filler cap with stock prom in ECM ..
        • Mitch DOHC
          • Jan 2004
          • 261
          sounds like u have a nlown head gasket
          1994 Cutlass Supreme Convertible 3.4 DOHC
          1969 Oldsmobile 442
          1997 Chevy Tahoe
          http://members.cardomain.com/mperkins442
          • Mitch DOHC
            • Jan 2004
            • 261
            make that blown
            1969 Oldsmobile 442
            1997 Chevy Tahoe
