AAAAAAAH! Phantom stalling again!
  • blk92z34getrag
    • 515
    #46
    Yeah I've heard from two other guys that they completely fixed the stalling problem with new injectors. I think (know) I'm going to get these injectors when I get the cash -- after I get my car painted and get my new wheels. Yeah the stalling is embarassing, but it really isn't an issue most of the time.
    --Rob
    • ryan.hess
      • 526
      #47
      After a long time of working perfectly with no problems, today it stalled twice, and gave me a code 32 (EGR) and code 35 (idle speed). I'm gonna pick up some 94 injectors for $50 today, swap em out, and let you guys know the results.
      Okay now, that's enough of that.
      • blk92z34getrag
        • 515
        #48
        Yeah sometimes my car will go like a month without stalling, then stall 5 times backing out of a parking space in a parking lot.
        As soon as I win the lottery I'm just gonna get the new injectors.
        --Rob
        • ryan.hess
          • 526
          #49
          I hear ya on both counts Got the injectors off, and they're different part numbers and different color "plasticband things"... I think that's a good sign? I called the local injector cleaners, and they said the same flow rates were used 91-97 on DOHC's. (I checked the resistance too, and that checks out) So... Assuming the problem on 91-93's is due to their injectors, swapping them out with a 94's should make it happy. (knock on wood) Well I have to go to the parts store for some O-rings before my house explodes into fire, so I'll keep you guys posted,
          • ryan.hess
            • 526
            #50
            Well it is now back together, and it runs (yay). But, I am not convinced it fixed the problem.... In fact, if anything, it may have made the problem worse. Granted, after resetting the computer, it always runs a little rougher, and dips rpm's a little lower, so this may just be a fluke, and it may be fixed. So far, it hasn't stalled. But, it has come very close several times! I'll take it out for a longer drive tomorrow probably... (sigh)
            • blk92z34getrag
              • 515
              #51
              Good luck man, I hope it fixes it, if it does that will be so much cheaper than buying the new spec. GM injectors.
              --Rob
              • ryan.hess
                • 526
                #52
                Well, I took it on a real long test drive today. I went the same route yesterday, where it stalled twice, and so far, so good! It seems to have smoothed out a bit, and I haven't seen the rpm's dip low. Unfortunately, while on the highway, my SES came on, and when I got home, it read 32 and 35 again (I reset the computer after installing the injectors).
                • blk92z34getrag
                  • 515
                  #53
                  Yeah it's weird whenever I take my car on a long drive my car will flash 32. As soon as I shut the car off and restart it, it'll go away. Once it did this and the car totally lost power, it wouldn't rev at all. Shut it off, restarted it, and everything was fine, and it only happened once.
                  Cranky ass LQ1's I tells ya.
                  --Rob
                  • joey b
                    • Feb 2004
                    • 75
                    #54
                    I get a 32 ALL THE TIME. I wouldn't worry bout it.
                    92 cutty auto with a 97 3.4
                    93 convert with 3.4
                    • dennisinmo
                      • 7
                      #55
                      Re: 93 Stalling Update post of Nov 24 and your stalling problems. We did fix the stalling problem with the GM injectors but the car still throws the 32 code when it is driven awhile. It goes away after the car is turned off and reappears when the car is driven and heated up. He just ignors it. We have cleaned the EGR tube, intake plenum and replaced the EGR with a new one. We figure you can only do so much.
                      93 Lumina Z34
                      Automatic
                      K&N Air Filter
                      • ryan.hess
                        • 526
                        #56
                        YAAAY! It stalled again! Now it's time to use it as a shooting car!
                        • Lyle's GTP
                          • Jan 2004
                          • 1345
                          #57
                          Welcome to the pain-in-the-ass club man.
                          Lyle
                          • ryan.hess
                            • 526
                            #58
                            I'm going to try one more related thing... changing the fuel filter. It hasn't been changed (EVER) and the tank is pretty rusty... Maybe after running xxx minutes, it starts getting loaded down, and can't idle? After that I'll change the IAC for good measure and ponder that $700 price tag some more
                            • Lyle's GTP
                              • Jan 2004
                              • 1345
                              #59
                              What $700 price tag?
                              Lyle
                              • ryan.hess
                                • 526
                                #60
                                For the TSB injectors??
