Aaah I need help!!!!
  • Z34 9294
    • Oct 2006
    • 2
    I have a 92 Z34 that ive been fighting for far to long now. The Cam belt flung from a bad pullie, so naturally I do my homework ( off this site mainly ) And go ahead and buy all my parts- pullies, belt ,tensioner gaskets etc. I got it all together and it was wrong not 1 time 5 dam times Help wht the F@3! could I be doing wrong. I made sure the flats on all the cams were up Crank at tdc at least im sure its there. It will start but it scares me to even hear it run. to me it sounds like it is 180 deg. out but how can that be ! Ive tried it every wich way possible and still no luck AAAAAAAAAaHHHHHH Thanks for lstenen
  • 3100 MPFI
    • 1522
    If you have all 4 cams UP, then it is wrong. When the front 2 cams are UP, then the back 2 should be DOWN.
    Taylor
    1998 Lincoln Mark VIII
    • Z34 9294
      • Oct 2006
      • 2
      cam timing almost there
      So I tried the left (back) bank with the flats up and then right Front bank with the flats down it will start and run , but its still a dog. should I of done that the other way around?
      • 3100 MPFI
        • 1522
        http://60degreev6.com/showthread.php?t=24975
        if you read that, and follow it, then it should be right. It has you tighten the cams with all of them up, but then you have to tighten the pulleys on one set, turn the engine all the way around to TDC again, then tighten the other set.
        Is this the way you did it? If not, then it is wrong.
        Taylor
