rusty ERG mounting bracket
  • napatiger
    • 490
    I had the hood off my 95 z34 and the mounting bracket that connects the EGR valve to the ?plennum is rusting...
    question is:
    Is that rust going to continue into the motor? Am I F'd or what?
    I am going to replace it in 2 weeks when the garage is available and the car is on its last ride before the engine rebuild.
    95 MC Z34 Black
  • Lyle's GTP
    • Jan 2004
    • 1345
    Hey I've got some experience with alloys. The plennum is cast aluminum it can't rust. It could corrode from chemical contact.... but the only chemical I know of in your car that can do this is old coolant (another reason to keep you coolant fresh, change it once a year, even the "longlife" stuff). But any how, the steel plate with the holes that attaches to the exhaust pipe, that part will rust but nothing to worry about.
    But I think what you are seeing is just a burnt exhaust film looks kind of rusty colored and goes down inside the EGR hole. I wouldn't worry thought.
