3.4 dohc performance info
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    just figured i'd throw a little out here for you guys after testing some hunches.
    1. mms headers do in fact fit 1st gen wbodies if u have 96-97 heads or engine. only thing i had to modify was i had to remove 1 piece of heat shielding from the firewall.
    2. the neutrally balanced getrag 282 flywheel for a 88 fiero does interchange with the 284 flywheel
  • napatiger
    • 490
    So I could get a set of the headers and just change the flange?
    Post a link to headers please.
    95 MC Z34 Black
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      ok, i'll click some pix for ya and post them. though you will not see too much b/c i wrapped them.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        here are a couple pix:
        • BlueFlame
          • Sep 2006
          • 36
          Hey fiend, who is this MMS and do they make any headers that would fit into my 94 GTP? Are they any good?
          1994 Grand Prix GTP
          LQ1
          4T60-E
          FFP UD Pulley
          K&N
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            hey, mms stands for milzy motorsports. these headers are in fact in my 94 gtp right now. unfortunately they do not make headers for the 91-95 lq1, only 96-97(or just swap on 96-97 heads to a 91-95 lq1).
            my engine is newly rebuilt and i still have to put enough miles on it to break it in be4 taking it to the dyno and thrashing it. one other guy put a set on his relatively stock monte and netted 12hp to the wheels untuned and hooked up to his stock exhaust i believe.
            there is a catch though. he is not fast at all, actually he is quite slow. i think it took me 2 months to get mine. also his prices are not cheap, i think it is 700 and some change for a uncoated set. although i got mine much cheaper than that in exchange for beta testing them on my gen1 wbody .
            it was tight as you can see by the pix but they fit. only modification i had to do was remove the upper heat shield on the firewall and i had to lengthen the wires for my 02 sensor.
            p.s. b/c of the fit and installation, they are not equal length or anything, just a FYI.
