Need More Power
  • pontiacdohc@gmail.com
    Pontiac DOHC
    • Feb 2006
    • 181
    Need More Power
    Anyone have any ideas Im looking for a little bit more out of this car..
    Can yo usee anywhere where it is lacking by looking at the numbers ?
    jetchip... NEED A 60DEGREE CHIP !!!
    No CAT 2 1/4 Turbo Mufflers
    Wires Ac Delco Rapid Fire Plugs
    180 Stat
    CAI
    HEAVY WHEELS lol
    Rt-. 0699
    60ft- 2.5441
    330ft- 7.0661
    1/8 ET- 10.7130
    1/8MPH- 67.56
    1000 ET- 13.7999
    1000 MPH 79.05
    1/4 ET- 16.2989
    1/4 MPH- 87.12
    1997 Chevrolet Camaro 30th Anniversary 5Speed.
    3800 V6 (i know its not a 60degree)
    stock for now
    1993 Special Edtion/GTP
    3.4 DOHC V6 LQ1 SOLD!
    CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
    180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
    VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    1st response i always give to this question is what is your budget?
    next, how deep do you plan to tear into the car?
    last, what type of tranny do you have? auto or manual.
      Pontiac DOHC
      • Feb 2006
      • 181
      I WANT TO BREAK INTO HIGH MID 15'S. lOOKING FOR MORE BOLT ON APPS. I THINK MY HEAVY CHROME WHEELS HAVE A PLAY IN THIS TOO. AS FOR BUDGET I WOULD LIKE A GOOD HP/$$$ RATIO AND IM RUNNING THE 4T60E I HAVE FOUND THAT IT IS FASTER IF I MAN SHIFT IT AND RUN 2 ALL THE WAY OUT
      stock for now
      • BlueFlame
        • Sep 2006
        • 36
        I would say something along the lines of 96+ intake swap and the Miltzy headers. Also, the FFP UD pulley may help a bit too. If anyone disagrees, let me know, as I kinda new to the LQ1 business too.
        1994 Grand Prix GTP
        LQ1
        4T60-E
        FFP UD Pulley
        K&N
        • dohcfiend
          King Chalupa
          • Jan 2004
          • 2351
          your idea of good hp/$$$ ratio may be different than mine. let's come up with a number. 1000? 2000?
          it's ok i am not trying to sell you anything but i need to know what you are looking to spend.
          id say put it in d and let the tranny shift it. how about powerstalling, you do that?
          bolt-on. for starters, get yourself that pulley and dogbone at the same time, save yourself some shipping, port your intakes, relocate one of your mufflers further upstream and run 1 muffler instead of 2. less exhaust backpressure and weight reduction. strip out your trunk, remove the sound crap from under your carpet, get a set of stock wheels or lighter ones for the track, remove those 2 diagonal braces, remove the insulation from underneath the hood, install a full coilover kit, port your exhaust manifolds and crosspipe, change your cam timing and get a chip.
          i think that just covered about every bolt-on there is. looks like a little over 2000 there. you could cut corners and drop the coilover kit(900 give or take) i wouldn't worry about the 50,000 coils for now.
          edit: oh and stickier tires
