Need 1996 DOHC engine harness
  • RedZMonte
    • Feb 2004
    • 1378
    anyone have a 1996 engine harness laying around they want to get rid of? im going to be doing a OBDII/C100 swap and need a harness and ECU. It must be a 1996.
    Please let me know, im looking to do the swap asap.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
  • Guest
    nevermind*
    • RedZMonte
      • Feb 2004
      • 1378
      I got a harness.. Disreguard
      Shane "RedZMonte"
      • z34phoenix
        • Jun 2005
        • 469
        was going to say i'll swap my 96 for a 97 harness
        • lkurek
          • Aug 2006
          • 153
          OK....that being said....
          I know the OBDI and OBDII differences, but what are the 1996 to 1997 differences?
          I'm putting a 96 DOHC motor into my 95 Lumina that has a nice old (262k miles) 3100 in it. While it runs great, I'm sure I am on borrowed time.
          So, I have a 96 motor and I grabbed a 96 harness from the boneyard.... Should I have picked up a 97 harness instead?
          Gracias!
          • RedZMonte
            • Feb 2004
            • 1378
            Gracias!
            1996 has a "C100" computer. 1997 has a OBDII. but both work about the same. In 1996 GM didn't know how to make a OBDII so this was their 1st attempt at it. The 1996 computer will run the 4T60-e. 1997 from what i understand has a 4T65-e. Not sure other then that. I was told that i need to get a '96 to work with my tranny.
            S
            Shane "RedZMonte"
            • timg
              • Feb 2004
              • 718
              Yeah, the 97 runs the 4T65E and the 96 runs the 4T60E. Other than that, they're VERY similar. Only a wire or two on the firewall C100 connector changed.
              Shane,
              I got your message about the harness. I'm actually planning on using my 96 harness first. Only if things don't work out well with the 4T60E will I switch to the 4T65E and 97 harness.
              Tim
              325 whp 350 lb-ft
              • RedZMonte
                • Feb 2004
                • 1378
                Shane,
                Tim
                Cool. I just recieved my 96 harness and computer in the mail from a Junk Yard in OR. Going to be a long weekend
                Shane "RedZMonte"
                • RedZMonte
                  • Feb 2004
                  • 1378
                  Tim
                  So if i swap the harness w/o changing the couple wires, will it run or do i need to do that befire it runs. i know i need to add a knock sensor, will it run w/o the sensor? Also where is the knock sensor located.
                  Shane "RedZMonte"
                  • timg
                    • Feb 2004
                    • 718
                    If I remember correctly, the extra knock sensor was on the front of the block where the current coil packs are. I think it will run without it, but I do not know how it will affect power output and knock control.
                    There are some wires in the C100 firewall connector that will need to be swapped. I think this is the summary based on the spreadsheet I posted:
                    Move A3 to E1
                    J2 is for the OBD2, you will need to add a wire from this to the OBD2 port
                    L1 run new wiring with a 60 amp fuse. This was a battery feed on the 95.
                    Tim
                    325 whp 350 lb-ft
                    • RedZMonte
                      • Feb 2004
                      • 1378
                      I will have to double check to see if i have another connector for a 2nd knock sensor or not. dont remember seeing one, i could be wrong tho.
                      Shane "RedZMonte"
                      • RedZMonte
                        • Feb 2004
                        • 1378
                        Im a Fuktard, Yep there is a front knock sensor connection. I need to find a place to put it in. everything is done except the Knock sensors and the firewall harness pin swap. should be done tomorrow.
                        Shane "RedZMonte"
