Will the IROC Camero Wheels fit on the Z34 Lumina? I'm sorry but I get a hard on every time I see them.
Will IROC fit Z34?
wrong offset and bolt pattern.
GM FWD cars use a 5x115 bolt patter and a 25mm(TGP), 38mm(Z34, Grand Prix, Cutlass, ect..) or a 52mm (1997+ GTP, Regal, ect...) offset depending on model and year.
The camaro is a 5x114.3/5x4.5 bolt pattern and a much lower offset. RWD offsets are much different then FWD offsets.
So to answer the question no. Not a direct bolt on.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Don't S10s have the same bolt pattern as Camaros? I have seen crosslaces on an S10 already, but the offset would work on an S10.I may own a GTO now, but I'm still a 60V6er at heart.
almost all RWD GM's were the same bolt battern except Caddy's, some had some huge pattern.Originally posted by OldSkoolGP View PostDon't S10s have the same bolt pattern as Camaros? I have seen crosslaces on an S10 already, but the offset would work on an S10.
Newer Fbodies have a very similar offset to the FWD cars although the bolt pattern is different.
