C100 Swap update and ?
  • RedZMonte
    • Feb 2004
    • 1378
    So i got the old harness 99% out. just need to pull the Alt. and remove the connections on the alternator and the '95 harness is out. Any Tips on getting the Alt. out. I have never done one myself, im sure i can figure it out but just wanted to make sure there wasnt anything tricky.
    Couple questions. What sensors do i need to add? I know the EGR is one and 2nd O2, but im going to disable them using HPT. Do i need to add another knock sensor? if so where is it added.
    Answered my 2nd question
    these are the questions i had. everything else looks to be straight forward.
    Thanks in advance
    Shane
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
  • RedZMonte
    • Feb 2004
    • 1378
    the 2 wire plug is for the power steering pressure switch.
    Shane "RedZMonte"
    • pwmin
      • Aug 2004
      • 394
      what did you have larry do yesterday, shane?
      91 GTP HM-284 GONE :(
      98 Spawn of Satan (L67 Regal)
      87 V10 SM-465/Mild 350
      06 Cobalt SS/SC GONE :(
      • RedZMonte
        • Feb 2004
        • 1378
        If i leave it unhooked it will not have power assist at low speeds and reverse. No biggie.
        The swap is pretty straight forward. I did have to swap the connectors from the old harness to the new one for the transmission neutral safty switch i believe. other then that it plugs right in. Altho i does appear that the harness is shorter in some areas had to strech a couple wires . I have just the UIM to install again and also swap the knock sensor from the 1995 to the 1996 and hookup the alt and i think its ready to fire up.
        I did notice a couple pins on the firewill harness are different, so i may need to swap them around.
        S
        Shane "RedZMonte"
        • timg
          • Feb 2004
          • 718
          Did you do all of that with the engine in? Good luck!
          Tim
          325 whp 350 lb-ft
          • RedZMonte
            • Feb 2004
            • 1378
            Tim
            Yeah i did the swap with the engine in. the harness went in easier then it came out i can tell you that for sure. but other then reaching the rear knock sensor everything went pretty smooth. it was about as easy is i antisipated. i did have to ratchet the motor forward and also yank the turbo out to get everything tho.
            S
            Shane "RedZMonte"
            • RedZMonte
              • Feb 2004
              • 1378
              Well the car started and ran last night. I need to get the rear Knock sensor replaced so i can read knock and also swap the DLC to the OBDII Style. and we are good to go.
              Shane "RedZMonte"
              • RedZMonte
                • Feb 2004
                • 1378
                I also have a 3 wire connection on the engine harness between the TPS/IAC and the EGR, anyone know what it goes to?
                The bulkhead connector was a snap. Pwmin and i added a 12v power w/ a 60amp maxi fuse to L1 and swapped E1 to A3 (pink wire) and she started. I found the OBDII data link conector for $2 P/N: 12110250 and will need to add a signal wire.
                Shane "RedZMonte"
                • timg
                  • Feb 2004
                  • 718
                  MAP sensor.
                  I'm glad those swap directions work. That sounds like a really easy wiring harness mod!
                  Tim
                  325 whp 350 lb-ft
                  • pwmin
                    • Aug 2004
                    • 394
                    yeyah. now, i cant wait to do it to mine
                    now, i have a 96 block, so i have provisions for both knock sensors and the crank and cam position sensors are there, but i have 91 cams, so my cam position sensor wont be useable since the cams dont have the reluctor ring. do i need the 94+ cams or can i just remove the fault reporting forthe code(s)?
                    • timg
                      • Feb 2004
                      • 718
                      I think you actually need the cam
                      Tim
                      325 whp 350 lb-ft
                      • pwmin
                        • Aug 2004
                        • 394
                        Tim
                        DRAT
                        • RedZMonte
                          • Feb 2004
                          • 1378
                          MAP sensor.
                          Tim
                          The map sensor is up by the TB on the '96? everything was easy except E1 to A3 not A3 to E1. E1 is a small wire (16 gauge i think) and A3 is a large wire (12 gauge or so)... I crimped it on anyhow and hope it will be fine. if not i will have to trace the wire and run a new wire.
                          I also need to know if 2 knock sensors are required, if so i need to find a place to put the 2nd (Front).
                          S
                          Shane "RedZMonte"
                          • RedZMonte
                            • Feb 2004
                            • 1378
                            Once i add J2 i can also swap to the new style DLC. It appears you need to add another ground to the new sytle DLC. P/N: for the data link is 12110250. allot of dealers don't stock it and you have to buy a pack of 5 to get them. Luckly they are ~2.50ea.
                            Shane
                            Shane "RedZMonte"
                            • timg
                              • Feb 2004
                              • 718
                              Sorry about getting those wires mixed up. I fixed the spreadsheet now.
                              The MAP sensor is just behind the TB on the intake arm. If you find a stock one, you can probably remove the rubber grommet on it and run it through a vacuum hose to the intake.
                              Tim
                              325 whp 350 lb-ft
