Part# for RapidFire Plugs
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    Does anyone know the Part# for the AC Delco Rapid Fire Plugs?
    Even better do you know the Part# for the Rapid Fire Plugs that are two ranges colder for my 3.4DOHC 96 GTP.
    THanks
    I dont know what this means but "ASS HATS" is funny
  • gpchris
    • Feb 2007
    • 477
    Did you know that you have to remove the upper intake to get to the rear plugs?
    • Carlspike
      • Oct 2005
      • 154
      Not if you are willing to remove some weatherstripping and bend a little bit of metal.
      • gpchris
        • Feb 2007
        • 477
        I'm not 100% but i'm pretty sure that the upper intake covers them on the 96-97. even if the engine was out i don't think you could get them..
        • Carlspike
          • Oct 2005
          • 154
          Since you can put the 96/97 intakes on the 91-95 I wouldn't believe them to be different enough to cover the spark plugs. That would be one extremely wide intake. I didn't read that his year car was a 96, the year and the type might matter because of engine placement in the engine bay. I could be wrong, but I know it worked on my 92 Z34.
          • gpchris
            • Feb 2007
            • 477
            The 91-95 spark plugs are easy but honestly i heard that the 96-97 cover them up...
            • RedZMonte
              • Feb 2004
              • 1378
              from what i remeber you have to pull the intake to get the rears in the 1996-1997. My 95 i just rock the engine and set the park brake and walla. If i remember correctly rapid fire #12 is the plug. i would just run standard delco's or NGK's. No gain with the rapidfire if you ask me.
              The 1996 UIM is much different from the 1995 and earlier.
              S
              Shane "RedZMonte"
              1992 Lumina Z34-VIRGIN (RIP)
              1992 L67 Lumina Z34 (SOLD)
              1990 Turbo Grand Prix (SOLD)
              • pwmin
                • Aug 2004
                • 394
                you absolutely do have to pull the plenum on 96+, but it only takes 5 minutes once youve done it a couple times, esp. if you dont have to replace the UIM and intake arm gaskets.
                91 GTP HM-284 GONE :(
                98 Spawn of Satan (L67 Regal)
                87 V10 SM-465/Mild 350
                06 Cobalt SS/SC GONE :(
                • 93Oldsdroptop
                  • 167
                  I put Rapidfire 8's in my 3.4. The lower the number, colder the plug.
                  '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
                  '06 Dodge Magnum SXT 3.5L -- My Daily Driver
                  • Identity Crisis
                    Lost at Birth
                    • Jul 2006
                    • 295
                    It went a little off topic there guys but I go the answer in the end.
                    Not too worried about removing the UIM as I plan on picking up a spare at the salvage yard and polishing it then maybe anodizing it before I install it.
                    Can I detach the neck and leave the Neck and TB in place when I remove the UIM?
                    • pwmin
                      • Aug 2004
                      • 394
                      yep.
                      • Identity Crisis
                        Lost at Birth
                        • Jul 2006
                        • 295
                        Rapid Fire #8s wouldnt that be 4 ranges colder?
                        • Carlspike
                          • Oct 2005
                          • 154
                          I stand corrected. Does anybody have pics comparing the 2 intakes?
                          • gpchris
                            • Feb 2007
                            • 477
                            this is the 96-97 upper intake:
                            And this is the 91-95 upper intake:
                            • Identity Crisis
                              Lost at Birth
                              • Jul 2006
                              • 295
                              holy crap it took the guy at GM 15min to find a part# for #10Rapidfires. They will be in Monday. Sweet.
