Power wire upgrade?
  • RedZMonte
    • Feb 2004
    • 1378
    Power wire upgrade?
    ZZP has a upgrade cable from the back of the alternator to the power post on the L67/L32/L36's. I guess it makes a good difference. Has anyone done this to their DOHC? That might be this weeks "Cheap Mod"... Well along with my F'ed up fuel pump getting replaced.
    My battery is in the trunk so i think this would help quite a bit.
    here is what im talking about:
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
  • d.o.h.c
    • Jun 2004
    • 981
    Upgrading the wiring helps alot. I put my battery in the trunk and never was able to get the car to start when it was hot. Maybe it was the starter from heat soak, not sure. But I replaced everything. I am running a 2ga power wire from the battery to the starter, no to the post, directlty to the starter. The alternator has 8ga wire from the factory. Unless you are going to have alot being drawn from it I think factory is ok. I think this is a good mod if you need to do it, but not just beacause you can.
    • RedZMonte
      • Feb 2004
      • 1378
      My battery is in the trunk. And like it says in the right up on zzp. the factory wire is small and long. so running the cable from the bat post to the alt. directly will allow you to have brighter headlights and stronger power for accessories. people with large sterios should also benifit from this mod too. (i have. 3 amps)
      S
      Shane "RedZMonte"
      • d.o.h.c
        • Jun 2004
        • 981
        I see what your saying. Ahh, well go for it.Let me know if it does anything. I have custom made hid with projecotrs coming so I am goof with headlights
        • pwmin
          • Aug 2004
          • 394
          i just ran the wire over the weekend, just need to get a fuse holder.
          doing the "big 3" or "big 5" is always a good idea.
          91 GTP HM-284 GONE :(
          98 Spawn of Satan (L67 Regal)
          87 V10 SM-465/Mild 350
          06 Cobalt SS/SC GONE :(
          • RedZMonte
            • Feb 2004
            • 1378
            Ummm.... well....this is the first ive heard of the big 3" or 5".... 3 isnt big...... letalone 5
            LMAO! J/P
            S
            Shane "RedZMonte"
            • pwmin
              • Aug 2004
              • 394
              for a gorilla, it is
