Anyone M90 a 3.4DOHC?
  • RedZMonte
    • Feb 2004
    • 1378
    Originally posted by OldSkoolGP View Post
    350WHP is sick. But that much power in a FWD car is useless. You'd never be able to use all of the horses except at the strip with a pair of slicks. Honestly, I think for ability to use all your power 300HP is the max on a W-body, probably 250HP on a J-body.
    There are GTPs with 400+ to the wheels and they do spin a little on the street, but it is still fun . 300hp Turbo is much different then 300hp S/C. but in colorado you need all you can get from a dig. they are a terd up here.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    • xtacyZ34
      X-Ru
      • Apr 2009
      • 8
      do they make a 96 CAI?
      • Dave96z34
        • Apr 2005
        • 624
        Wow dug this topic up. No not for the Monte you have to make your own.
        • Schurkey
          • Apr 2007
          • 339
          Originally posted by RedZMonte View Post
          Curious. What's the belt life; and what's the supercharger drive shaft bearing life on that unit?
          To me, that's a piss-poor design. There's two, maybe three inches of overhung shaft being pulled on by the belt. Then, a long unsupported section of shaft before the second bearing.
          Seems to me that with the load from the belt, the drive shaft would be induced to whip 'n' wobble in the middle; and perhaps fatigue crack on the overhung part.
          Redesigning the first bearing housing to reduce the overhang would go a long way toward reducing shaft whip.
            • 9191
            Are you sure that is the shaft, and not just a shaft housing?
            • Schurkey
              • Apr 2007
              • 339
              #21
              Based on the grease zerks on the bearing housings--yeah, I'd say that was the shaft.
                • 9191
                #22
                Maybe the zerks go through the brackets and into the shaft housing...
                But, yeah, that makes sense...
                • Dave96z34
                  • Apr 2005
                  • 624
                  #23
                  Looks like block bearings I would say it has no housing.
                  • choppester
                    • Mar 2006
                    • 57
                    #24
                    kinda like this, sorry its sleeping under a garage right now but i've had it done since the starting of spring and never got around to taking pictures of it and had to dig up this one. and about 300hp maxing out and what not, what about gearing???? that doesn't make sense. 3800 gtp's that are fwd that run 11's and 10's. proven anything is possible. suspension, gearing and tires helps you get thoughs numbers. a 3800 on f1 tires (street legal) ran 12.7 1/4 time and yea is squawked bad and still made that time. I know it can be done cause I was the one who built up that gtp..
                    • RedZMonte
                      • Feb 2004
                      • 1378
                      #25
                      I would not be affraid to run the intermediat shaft with the charger like the sho has it.. Keep the carrier bearings greased and your fine. Some have a housing over the shaft some don't. I strictly used this pic to show an example of it..
                      The issue i see with mounting it in place of the A/C compressor is space.. It would be awfull close to the rad/fans and you would have alot of piping, not to mention the piping would run right past the exhaust manifold and heating up the charge...
                      Here is an example with the housing over the shaft. RIPP charger for a 3.0L Eclipse
                      Shane "RedZMonte"
                      • Dave96z34
                        • Apr 2005
                        • 624
                        #26
                        You just run a shorter thicker rad on the other side and run the piping forward in to a IC and out the other side and up were the battery is and in to the TB. That's vary easy to do. The only thing that concerns me with his rig is the cast alum on the timing cover. There are just 3 bolt holes and none are vary strong. But if he add more bolt holes and a brace to the engine block or if he has the money build a new timing cover he be all set.
                        • choppester
                          • Mar 2006
                          • 57
                          #27
                          dave called it out just right about the piping location. the three bolt holes work out great. they held up fine we put enough pressure on it so that there's no way its going anywhere.... I'm a toolmaker and ase tech. i fabed this bracket with t6 aluminum. the intake piping..... ahuh look at the pics again it runs right in front of the vents, its not even close to the exhaust manifold.. the radiator is mounted to the right of it. a custom air filter was made cause it was cutting it close. i'll have to get pics posted later when i get a camera again for you to understand
                          • savannaz34
                            • Jun 2008
                            • 72
                            #28
                            why?
                            why couldnt you just turn the pipe down right away to a inter cooler?
                            like on the z34 lumina,it has a perfect spot down in the front.i dont know what car you guys are refering to,or if it has a bumber cut out like the lumina.
                            but if a guy has all the money and skill to do this work,than im sure he could buy or fab up a front bumper cover,and make it look good.im not trying to be a dick head or anything,and i also dont like the import look.but i thought it might be the best way to cool the charge?
                            • savannaz34
                              • Jun 2008
                              • 72
                              #29
                              where do get one of those from? do you have to change anything else?(injectors,plugs,chip)will it work with OBD1?
                              • Dave96z34
                                • Apr 2005
                                • 624
                                #30
                                I just looked at my spare block I see what you mean that should hold nicely
                                Still a brace to the engine block would help. Another concern is engine movement. Just make sure you get a nice flex silicone joints or you may tare the ic up. Engine may twist 10deg or more. I like it!
