Timing. WAIT A MINUTE!
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    Couldn't I set the cams to stock settings, then pick a cam, loosen the lock bolt, put my degree wheel on the crank, and rotate the crank the desired degree's for cam settings? So what I should be setting for (96 3.4) is crank rotated 12 deg clockwise for exhaust, and 4 deg clockwise for intake. right?
  • series8217
    • Dec 2004
    • 387
    You can do it that way but you need to somehow hold the cam in position while you're tightening the bolt.
