mods??
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    mods??
    this is about modifying the motors we love/hate. 2 things 1 list your mods and what you believe they are worth 2 does any1 have proof of what a single mod is worth or maybe a sum of their mods(ie real dyno). im curious what you guys have done.....well the ones that don't list the mods in the signature anyway j/k. and im hoping the peeps with the dynoed mods maybe i could use them as guidelines to maybe give me an idea what some of mine might be worth.
    (these claims are just what i think they might be worth or maybe have read some claim somwhere about)
    i'll go first:
    MAF screen removal: i have read it is worth(i believe it was zz performance but not certain) 2hp
    cat gut: 5hp 7tq, guess
    cold air intake: 5hp, guess
    K&N: 2hp, guess
    50 shot: it better be worth 50hp 50 tq,guess
    b&m vacuum modulator: well it is a mod but not worth anything(really it is worthless i will use it as a selling point someday and maybe the buyer won't realize it is worthless).
    i am particularly interested in 13* timing mod, different mufflers, and an underdrive pulley.
  • dykz34
    • Jan 2004
    • 793
    I've read that removing the MAF screen is actually detrimental because the honeycomb is used to even out the airflow over the sensor... without it you could get inaccurate readings.
    I dynoed 25hp over stock with mufflers, UD pulley, chip, and intake. You do the math. Funny part was that tq was still the same.... Oh well.
    • blk92z34getrag
      • 515
      Custom Cone Intake by Intake Power (Definate butt dyno difference with rain gutters off)
      Magnaflow 2.5" High-Flow Catalytic Converter (Very little difference, better than blown-out stock cat.)
      FFP Custom Tuned Chip (BIG difference)
      Hypertech 160 Degree Thermostat (going to a 180* this weekend)
      Flowmaster 40 Series Mufflers (Little difference, good sound)
      Some American something-or-rather glasspack resonator (Sounds awesome)
      Yeah... no dyno results yet, but it is definately faster than stock. There's a dyno shop near me, I'm gonna take it there probably in May, after I get my new wheels.
      --Rob
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        that's at the wheels!!!?
        intake?
        is that an air intake tube or a different intake plenum?
        • Cotton
          • Feb 2004
          • 33
          Any of you guys played around with diiferent injectors?
          A buddy of mine has a GN, and he gave me a set of 33lb/hr injectors after he went to a 42lb.
          proud supporter of \"W\"
          • Mitch DOHC
            • Jan 2004
            • 261
            under drive pully
            jegs 45,000 volt DSI coils, rapid fire plugs
            fast chip computer chip
            K/N cone filter with a cousten built intake tube.... or actually a modifyed V6 honda intake tube
            3100 stall torque converter, performance clutches
            polley dog bone engine mount
            dyno max mufflers
            no dyno for me either... sorry
            1994 Cutlass Supreme Convertible 3.4 DOHC
            1969 Oldsmobile 442
            1997 Chevy Tahoe
            http://members.cardomain.com/mperkins442
            • Crimson Fury
              dropped your pocket
              • 111
              intake; best would be to go w/CAI. battery relocation needed, lest you dont have ABS. hop to mymonte.com and hit up Red Z for that. the 13* by itself is good. to get the full effect, port & polish your heads, (AT)3 angle valve job and deck em. tapering the throttle body, p&p'd intake(s)
              http://www.w-body.com/forum/viewtopic.php?t=24111
              Car Domain site!
              13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
              • brian89gp
                • 554
                MAF screen, it has been debated to death and hasn't been proved beyond a doubt either way. If you got a air filter on the end or a bend right before then the screen might be a good idea to get accurate readings at low flow.
                For injectors, going larger will do nothing. Air makes power, fuel only supplies the means.
                • dykz34
                  • Jan 2004
                  • 793
                  intake?
                  20hp more at the wheels, which equates to 25 at the crank assuming 20% loss. At the time, I had the infamous RedZ intake w/ a 7" S&B filter. Plenum was stock.
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    ud pulley
                    i am going to be getting a pulley soon and i saw a few of you guys have one. can you guys give me a part number for a new belt?
                    FYI: also just for the hell of it i will have some exhaust work done very soon, so that just leaves the cam mod.
                    • torq455
                      If I only had money!!!
                      • 1615
                      I have a 97 lumina 3100. I took the MAF screen off. It runs just like it always has with absoultely no problems. I have noticed a little better throttle response with more WOT power. I'm guessing about 5 hp. My mileage is still the same, and the plugs look fine. I took the cat off. The difference to me felt just like the UD pulley did, so I figure about 10 at the most. The pulley is from fastforwardperformance.com and has been dynoed at 10hp @ 5500rpm. The K&N air filter--I didn't really notice anything, hp or mileage wise.
                      Andy
                      fastest 1/8: 10.19@ 67.17
                      fastest 1/4: 16.16@ 82.70
                      • dykz34
                        • Jan 2004
                        • 793
                        There's your belt part number.
                        • dohcfiend
                          King Chalupa
                          • Jan 2004
                          • 2351
                          u da man
                          • 93LuminaZ34va
                            • 144
                            OOoooooo..... my dad works at NAPA..... Easy to find that belt now lol
                            1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
                            1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
                            1962 Buick Electra 225 STOCK... and gonna keep it that way
                            • Anonymous
                              True Cold Air Intake/K&N Filter
                              Polished Upper/Lower Intakes(waste of time and dremel bit)
                              FFP Chip
                              FFP UD Pulley
                              FFP Dogbone mount
                              Full Exhaust, 2.5" Mandrel Bent
                              Magnecore Competition 8.5mm wires
                              AC DEelco Rapidfire 8 plugs
                              Coming REALLY soon-
                              Headers
                              P&P Heads and both intakes
                              96 upper/lower intakes
                              SI Valves/Springs
                              Reground Cams
                              New Trannsmission becuz I like not having a 2nd gear....
                              There!
                              lol
