New dyno numbers, 415 WHP
  • Matt Hawkins
    • Jul 2007
    • 20
    I know a lot of people are interested over here. I put down 415 WHP with my 3.4l DOHC Turbo Fiero. Thread is here:
    http://www.fiero.nl/forum/Forum1/HTML/066752.html
    Matt
    1987 Fiero GT - 95' 3.4l DOHC LQ1, GT3071r turbo, intercooled, Haltech E6K, custom stainless headers and exhaust, Tial 38mm wastegate, 38 lb/hr MSD injectors, custom intake manifold, 12" 4-piston front brakes, 11.25" rear.
    415 WHP, 11.92 @118 1/4, 28 MPG, on pump gas.
  • TurboGt
    • Oct 2005
    • 154
    Awesome numbers man!!!!!
    After reading the PFF posts I was wondering how much timing you are running up top?
    Mega Squirted Fiero
    How I did it here
    • Matt Hawkins
      • Jul 2007
      • 20
      I am running about 16 degrees at peak torque and 20 degrees at peak power. That is at ~1 bar. I run the stock timing map up to atmospheric and ramp down from there to these values as boost increases.
      • TurboGt
        • Oct 2005
        • 154
        Would you mind sharing your table?
        Mega Squirted Fiero
        How I did it here
        • Matt Hawkins
          • Jul 2007
          • 20
          No problem. It will be a CSV file. I should have it available tomorrow.
          • d.o.h.c
            • Jun 2004
            • 981
            Wow, whats done to your motor
            • TurboGt
              • Oct 2005
              • 154
              Cool thanks!!!
              Mega Squirted Fiero
              How I did it here
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                damn, raised the bar a little higher.
                the 1st dohc to break 400whp, woohoo.
                there is a build thread somewhere in the pff archives on what he put into it. from what i remember there really wasn't much over a regular rebuild other than the custom pistons.
                very..VERY impressive for a relatively stock bottom end designed nearly 20 years ago.
                good job matt.
                  Live life 3.7mi at a time
                  • 4555
                  Nice! I can't ever get sick of the sound of a spooling turbo. I like the camera angle at the track, too .
                  • ez112
                    • 258
                    God damn. The sound of that engine...
                    1999 SVT Lightning
                    1996 Monte Z34 R.I.P.
                    Next BEATER: a C5
                    http://www.fquick.com/ez112
                    • Matt Hawkins
                      • Jul 2007
                      • 20
                      On the surface, not much, but many hours have gone into this. The only non-stock parts internally are ARP bolts in the bottom end and hypereutectic pistons. I did port the combustion chambers to unshroud the valves and lower compression ratio a bit. I left the ports alone as they are already pretty big. I made a custom intake manifold using the stock base manifold and fuel rails. I am running the stock Fiero throttle body. Here is a brief list of the modifications.
                      3.4l DOHC V6 from 1995 Monte Carlo
                      Ported/polished combustion chambers; good bolts in bottom end; hypereutectic pistons; custom intake manifold; 38 lb/hr injectors; Haltech E6K ECU; custom tubular stainless headers and crossover; GT3071r turbo; Tial 38mm wastegate; Fidenza Al flywheel; Clutchnet six puck sprung hub clutch with stock pressure plate; large Ebay intercooler core with custom end tanks/draw fans mounted under car; I spin the engine to 7k with a 7200 rev limiter.
                      12.5" front discs from 2000 F-car; 4-piston fixed calipers; 11.25" rear disc with 2000 F-car rear calipers; front and rear lowered ~3/4"; 17x7 front rims with 235/40; 17x8 rear rims with 255/40.
                      • HayesPerformance
                        • 783
                        You'll have to write down a scroll as to what the engine / turbo build up consisted of to assist all the 3.4 dohc crowd that wants the right direction to go in a engine/ turbo build!
                        Way to go!!!!!!!
                        1991 Grand Prix STE
                        3.4 DOHC
                        1 of 792 Produced
                        Extensive Mods Done
                        1991 Lumina Z34
                        3.4 DOHC
                        Getrag 284 5spd
                        1 of 30
                        • HayesPerformance
                          • 783
                          perfect thanks!!!!!!!!
                          1991 Grand Prix STE
                          3.4 DOHC
                          1 of 792 Produced
                          Extensive Mods Done
                          1991 Lumina Z34
                          3.4 DOHC
                          Getrag 284 5spd
                          1 of 30
                          • HayesPerformance
                            • 783
                            What Compression are you roughly running?
                            1991 Grand Prix STE
                            3.4 DOHC
                            1 of 792 Produced
                            Extensive Mods Done
                            1991 Lumina Z34
                            3.4 DOHC
                            Getrag 284 5spd
                            1 of 30
                            • Matt Hawkins
                              • Jul 2007
                              • 20
                              I am not sure of the compression ratio. I would guess that I lowered it to around 8.5:1. Not a drastic change over the stock 9.25:1. I did the porting of the combustion chambers more to clean up sharp edges and unshroud the valves.
