Dropping out motor
  • grandprixgtp_91
    • Nov 2003
    • 758
    Dropping out motor
    Hi I started dropping the 3.4 out of my prix today and i have everything unhooked and i am just about ready to drop it out and i was wondering if there is anything i should know before i do this? i am gonna be rebuilding the motor and i have to replace the subframe so i dont care if it gets damaged. thanks
    Jake
  • patgizz
    The Plaid Bandit
    • 1071
    not really, it was actually pretty easy
    • grandprixgtp_91
      • Nov 2003
      • 758
      what do i do about the ac compressor? do i unhook it and push it aside , or what is the fastest way of doing it?thanks
      Jake
      • 4spdz34
        • 185
        i just left it bolted up to the block and i took the lines right off at the compressor
        • grandprixgtp_91
          • Nov 2003
          • 758
          yeah but dont u need to get the system drained then? i cant drive the car anywhere to get drained.
          Jake
          • 4spdz34
            • 185
            haha i didn't drain mine, its just r134a, it only creates the greenhouse effect no worries
              I unbolted mine and let it sit in the bay. Could use some decent sized wire or a wire coat hanger to hold it up so it doesn't fall.
              • Juglenaut
                • 1130
                HVAC will leak that freon out eventually
                I am back
                Mechanical/Service Technican
                  Yeah, when it hit the 3 year mark of me having the 91, the AC stopped working, so I took it in to have it charged because it was really hot that summer. They wanted to do a leak test on it to find where the leak was and wouldn't fill it without testing it. I didn't bother because I figured if it took 3 at least to leak out, it would be so small of a leak that they wouldn't fill it, and I didn't want to waste money on a leak they were not going to find. Stupid bastards. It still had a good charge in there, just not enough to turn the compressor on. That's why I left mine in the bay without disconnecting it. I didn't want to lose what was in there.
