throttle body DIY coolant bypass?
  • The Hulk!
    • Jun 2007
    • 47
    anyway to seal up the coolant going through the throttle body?
    pics are helpful
    thanks
    jordan
    Ps i know this is prolly the most newbie question ever lol
    PPS i kinda broke the top bolt (10mm) of the throttle body by accident i RTVed it but will it leak coolant? half the bolt is still in there and i dont have a tap
    2004 Grand Prix G.T.P T-72 Turbo 28PSI,BS cam.581WHP Sold..
    2009 G8 GT Cam,meth,cutouts,tune,LT's 420.1whp
    2003 Oldsmobile Silhouette Intake,Tune,Built Trans
  • z34phoenix
    • Jun 2005
    • 469
    if the bolt is still sticking out the back you could try some vise grips.
    you could use RTV or QuickSteel on the TB port for the coolent. you could also try a small lenght of tube and insert it in the pipe that connects the heater core to the lower intake manifold. on my Z the core i got for my ported manifolds had a crack there... so i just cut that section off and made a direct connection from the line to lower intake manifold.
    • Dave96z34
      • Apr 2005
      • 624
      best way is to bypass it
      • The Hulk!
        • Jun 2007
        • 47
        and that goes? where?
        sorry if i sound clueless lol
        jordan
        • The Hulk!
          • Jun 2007
          • 47
          ohhh
          • Dave96z34
            • Apr 2005
            • 624
            I realy should have made 10 of them and sold them off.
            • The Hulk!
              • Jun 2007
              • 47
              how do i make one? lol
              • z34phoenix
                • Jun 2005
                • 469
                dave even with that adapter, you would need to cut the bottom of the intake arm... might as well cut it and glue in a tube. i used quick steel.
                • Dave96z34
                  • Apr 2005
                  • 624
                  lol took 30 sec with the band saw to cut off.
                  • ez112
                    • 258
                    Thank god I won't be having that TB.
                    1999 SVT Lightning
                    1996 Monte Z34 R.I.P.
                    Next BEATER: a C5
                    http://www.fquick.com/ez112
                    • z34phoenix
                      • Jun 2005
                      • 469
                      why whats so wrong with it? i like it better then the N*'s..... yeah the N* is a bit bigger but they dont have a smooth shape... so the air doesnt transition as smooth.
