need basic ideas for my lumina
  • kyobukan
    5 SPD Z34
    • Jul 2007
    • 73
    (1) air filters
    (2) exhaust
    send me some links please. a quick search turned up nothing.
    thanks
  • z34phoenix
    • Jun 2005
    • 469
    -FWI or CAI (Fender Well Intake / Cold Air Intake)
    -180* tstat
    -Fuel filter change
    -change spark plugs if the plugs are whitish drop one heat range on the plugs
    -Strut tower brace
    all the above should be rather cheep... prob like $125 for everything
    next as for exhaust, go 2.5" from the cat and remove the first resonator.
    next some nice grippy tires like 235 or 245 wide tires.
    • latemodelnewbee
      • Jun 2007
      • 227
      Where do you get this strut tower brace?
      68 El camino 454 speed muncie 3.90 posi 12 bolt,
      80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
      60 Impala 2 door hardtop L79-327 T56 4.11 posi.
      83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
      91 Z34 now has a hm284. and belly pan in the works
      • tonythetiger57
        • Oct 2007
        • 1
        junkyard, kinda hard to find.
        • z34phoenix
          • Jun 2005
          • 469
          junk yard for the cuttlas STB but GMPP and GM parts direct carry it. it iwll be under the newer montes but with the correct bracket from ZZP it will fit our cars. (1st gen w body)
          • pwmin
            • Aug 2004
            • 394
            you can also make g/c/h-body stb's work, too: http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
            all cutlass supreme convertibles got front STB's too that can be used.
            91 GTP HM-284 GONE :(
            98 Spawn of Satan (L67 Regal)
            87 V10 SM-465/Mild 350
            06 Cobalt SS/SC GONE :(
