Fixing oil leak.
  • grandprixgtp_91
    • Nov 2003
    • 758
    Fixing oil leak.
    Hi i am doing alot of work on my brothers 91 GTP automatic , im doing the timing and porting and polishing the intake and plenum and fixing the oil leak and and purging the injectors. well ive never fixed the oil leak in these cars because my 91 GTP 5 speed never leaked oil. so i was wondering where you out the jb weld and how much to use? also how do you do sn idle relearn? thanks for any help.
    Jake
  • Juglenaut
    • Dec 2003
    • 1130
    I don't recommend JB weld in that area
    I am back
    Mechanical/Service Technican
    • grandprixgtp_91
      • Nov 2003
      • 758
      What do you recomend?
      Jake
      • Juglenaut
        • Dec 2003
        • 1130
        If anything of a seal nature use RV sealant, easier to remove incase the gear does fail.
        I am back
        • Juglenaut
          • Dec 2003
          • 1130
          On my first attempt I used a tight fitting O-ring that fit snug around the plug cap seat..
          I am back
          • funair8594
            • 20
            Jake
            taking the heads off.
            I tried the JB chooch move and it DIDNT work for me. Yes I cleaned it, let it dry for a couple of days--everything and it still leaked. Im in Florida and its damn hot down here, I think that's why it didnt work. Maybe if you're up north, but not here.
            While I had the heads off, it made it easy to change the hard stuff like the alt. and o2 sensor. If you're going to do everything that youre doing, Id do it right
            • Juglenaut
              • Dec 2003
              • 1130
              I didn't remove heads because I just put them back on a month before the leak happened.
              I am back
              • grandprixgtp_91
                • Nov 2003
                • 758
                How do you do an idle relearn?
                • Juglenaut
                  • Dec 2003
                  • 1130
                  I didn't relearn mine it was automatic after a short drive I thought....
                  Idle learn enabled???
                  I am back
