Getrag 284
  • MOTORHEAD
    • Mar 2008
    • 90
    Getrag 284
    i am in need of buying a GETRAG 284 transmission, anyone want to sell it? im intersted to buy it for my 1993 Z34. im new here tho.. also i have questions see if u guys cud help me out?
    -spark plugs= heard x4 bosch is bad for 3.4 dohc? what is the best for 3.4 dohc spark plugs? BOSCH platinum is better? or?
    - wiring for spark plugs= how am i able to install the bigger size such as 8mm, 8.2mm or bigger but those boots woudlnt fit in those size, is there any way to fix that or buy new kind to fit?
    i am in HIGH PERFORMANCES not stock or daily parts
    any recommendations would be helpful
    -1992 Red Z34 284
    -1990 TSTE
    -1991 GTP
    -1992 B Z34 parts
    -1992 R Z34 parts
    I use AC Delco Rapidfire #8 plugs and Magnecor KV85 Competition 8.5mm spark plug wires. Other then that, the stock ignition system is fine.
    • MOTORHEAD
      • Mar 2008
      • 90
      thanks.. but how about MSD 8.5mm wiring? whats difference? cuz its wiring's end boots are different? or that mangecor is designed for 3.4 dohc?
      -1992 Red Z34 284
      -1990 TSTE
      -1991 GTP
      -1992 B Z34 parts
      -1992 R Z34 parts
      • gpse3400
        • 1460
        what he said
        Lorenzo
        • gpse3400
          • 1460
          Magnecores are direct fit. MSD?? Its a good name Dont know if they make anything for the the 3.4..
          Yeah the boots for the engine side are propriertary to that engine.. the coil side is a regular 90 deg bend
          Lorenzo
          • MOTORHEAD
            • Mar 2008
            • 90
            allright thanks i will go with that for now unless i find other better way i ll update if so.
            -1992 Red Z34 284
            -1990 TSTE
            -1991 GTP
            -1992 B Z34 parts
            -1992 R Z34 parts
            • MOTORHEAD
              • Mar 2008
              • 90
              do u think if KV85 Competition R-100 Racing 10mm Ignition Cable will fit as well or just 8.5 is the max?
              -1992 Red Z34 284
              -1990 TSTE
              -1991 GTP
              -1992 B Z34 parts
              -1992 R Z34 parts
                For a street car, 10mm is probably an overkill on your engine and wallet.
                • OldSkoolGP
                  That guy over there
                  • 930
                  All oversize wires are pointless unless you're running an MSD ignition box and a turbo. To put it into perspective, I have the fastest N/A DOHC on the board at the moment, and I'm doing it with A/C Delco Rapidfire #8 plugs and the factory 7mm wires.
                    According to the guy that owned the 92 before me, the Magnecors fixed the "phantom stalling" issue the car used to have. So at least they did one thing, besides look nice and give me a piece of mind knowing I have wires that are far from junk.
                    • MOTORHEAD
                      • Mar 2008
                      • 90
                      yeah i agree with pocket-rocket with the difference of wiring sizes on mm. "phantom staller" is new to me and it cud make sense. but i have a point- my mother car 03 impala LS (my possible senior gift!!) i replaced the wiring and the coil packs to MSD, MSD wiring 8.5 mm it really gave a better MPG, factory highway MPG was 27 or 28 based on 60 MPH, but now after replacing those to MSD, it makes abt 31-34 MPG at 70 MPH, almost 40's MPG at 60 MPH and hell i dont like factory wiring these r gay PLUS my WZ34 is at 187K miles WITH ORGINIAL WIRING/packs/ module. its time for a better shock as mangecor 8.5mm with MSD PACKS with brand new moudle hooked to 3 adapter under packs (adapter between moudle to packs) to MSD ingition worth abt 565$ for that piece of box.
                      i might sell my WZ34 idk yet
                      -1992 Red Z34 284
                      -1990 TSTE
                      -1991 GTP
                      -1992 B Z34 parts
                      -1992 R Z34 parts
                      • MOTORHEAD
                        • Mar 2008
                        • 90
                        why i might sell my WZ34 because that i need a manual, lower miles on body, rust-free. my red Z34 is rust free, no engine no trans, minor body damages but will be needing replacing the front bumper which i dont want to because i need to keep it orginial.. manual from factory made not swapping in manual from auto, hell idk ha, help me out if u can
                        -1992 Red Z34 284
                        -1990 TSTE
                        -1991 GTP
                        -1992 B Z34 parts
                        -1992 R Z34 parts
                        • RedZMonte
                          • Feb 2004
                          • 1378
                          Stock delco wires are good but i have had problems with them breaking. I bought magnicore 8mm wires for mine cause they where the same price as the delco's. you don't need bigger. and the 8mm wires fit in the stock clips as well.
                          S
                          Shane "RedZMonte"
                          1992 Lumina Z34-VIRGIN (RIP)
                          1992 L67 Lumina Z34 (SOLD)
                          1990 Turbo Grand Prix (SOLD)
                          • GutlessSupreme
                            • Nov 2004
                            • 166
                            Do not buy aftermarket coils. Stock AC Delcos are as powerful as you will EVER need and will last a lot longer. There have been a lot of stories of MSD coils failing after only a few k miles. 10mm wires is definitely overkill, and AC Delco plugs are also as much as you'll ever need.
                            -Tony | gtsdurango.net
                            '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
                            '90 Turbo Grand Prix STE - ehh.. I'm working on it.
                            '92 Gutless Supreme SL - RIP 5.2010
                            '90 Turbo Grand Prix - RIP 6.15.2005
                            • RedZMonte
                              • Feb 2004
                              • 1378
                              I run NGK plugs (Adv. Auto doesn't stock my delco's anymore) and stock coils on my turbo setup. GM DIS is a good system no need to "Upgrade" it.
                              S
                              Shane "RedZMonte"
