My Z34 has no low end.
  • Octavarium454
    • Apr 2008
    • 20
    Well, I guess maybe this is what you get for buying a car for 300 dollars. It is a black 1992 Z34 Lumina. The thing took a forklift to the driver side (at least thats the only explanation I can come up with, as it was parked in a factory parking lot) and the alternator was bad along with the plugs.
    So I finally got the alternator and plugs in (both a blast to work on) and the some of the passenger side replaced but now the motor seems to lack any low end power. Lets just say I lost a race to my brothers 95 neon.
    Now, I have never owned a 3.4 litre motor before so I guess my question is if this is normal for this motor? I might of pushed it a little hard for not running in 3 years but I will not stand for my car being beat by a neon!
    Car: $300
    Insurance:$105 a month
    Knowing that you will pay for your car 2 times over before the bill comes: Depressing
  • z34phoenix
    • Jun 2005
    • 469
    well these motors are known for not making low end power. but top end is very good. i would look into the timing belt and trany... unless there is a compression issue.
    as for making the car faster, a gear swap is a very good boost. a long with swaping to the 96-97 intake manifold set.
    • Octavarium454
      • Apr 2008
      • 20
      Now that I think of it the tranny fluid was low, but I'll see what happens after driving it to school a couple days. I like the idea of the intake manifold, and I plan I putting a new exhaust on the car from the cat. There has to be a problem however so I'll look into the timing, or the trans.
      Thanks for the advice, and in such a timely manner.
      Well it looks like I'm going to the junkyard to find me some 96 monte carlos.
      Car: $300
      • latemodelnewbee
        • Jun 2007
        • 227
        Not trying to justify getting beaten by a neon but the you have to be careful Mopar let out some weird ones by “accident”. I had a 95 that ran a 16.1 et showroom stock and falling on its face in 3rd gear also tapped 145mph out in west Texas (verified by a state trooper friend) even though it was supposed to be governed at 110. None of the suspension, brake, or driveline parts matched up with a normal neon. The only give away that found about the weird ones was wheels full of rotors all the way around. I would have kept it if I could have a readily available supply of wear items.
        68 El camino 454 speed muncie 3.90 posi 12 bolt,
        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
        91 Z34 now has a hm284. and belly pan in the works
        • HayesPerformance
          • 783
          It wouldn't hurt to really check over the whole car really well, I would check compression, check for any vacuum leaks, give it a good tune-up ( plugs, wires, air filter, pcv, etc, etc. )and YES, check the timing belt!
          1991 Grand Prix STE
          3.4 DOHC
          1 of 792 Produced
          Extensive Mods Done
          1991 Lumina Z34
          3.4 DOHC
          Getrag 284 5spd
          1 of 30
          • Octavarium454
            • Apr 2008
            • 20
            Well let me be a little more detailed on the problem. The car acts like I am easing on the accelerator from between idle to 3500-4000 rpms. Then all of a sudden the motor wakes up and flies between 30 mph and 75 mph. After that it again acts like I'm going easy on the pedal. Because of this my 0-60 times are in the 10s.
            Now let me give you the details on how I lost that race with the neon...
            To start with that neon had a 5 speed manual, so when the race began I was expecting to start off behind him. So the race starts, and I pull in the lead right away. I HAVE VERY LITTLE LOW END AND I BEAT A MANUAL OFF THE LINE! So I was extremely pleased because I knew that once I got up to the higher rpms I knew that car was toast. WRONG! Approaching about 85 miles an hour, I see that neon, approaching fast and not slowing down. I end up losing the race to my hometown at the point where I should of been dominating.
            I now plan on selling my 300 dollar Z34 if performance does not improve. I figure that I can make about 1100 hundred dollars off it in profit and then go by a 350 camaro. But I love my Lumina, so I'm in kind of a messed up situation.
            *UPDATE* I for some reason randomly put the E-Brake on when I had it on stands to replace the alternator. Maybe it didn't release when I pulled the handle. Could explain why the car has somewhat decent performance between 30-75mph.
            Car: $300
            • RedZMonte
              • Feb 2004
              • 1378
              like stated above i would defiantly go over it very well.. I can say that in colorado 5000+Ft elevation my car is a turd (as is every car) from a dig. but in min. where i bought the car i could roast the tires. My car in colorado is a dog untill about 3200rpm then i revs fast and hard, this is kinda typical with the automatic's. but it does from what you described sound a little off... I would definatly have the timing checkd...
              Shane "RedZMonte"
              1992 Lumina Z34-VIRGIN (RIP)
              1992 L67 Lumina Z34 (SOLD)
              1990 Turbo Grand Prix (SOLD)
