lq1 info needed
  • project89
    • Sep 2008
    • 247
    lq1 info needed
    i just came across a guy who started to swap in an lq1 into his camaro but ran into a few issues.
    they are all pretty minor
    #1 hitting heater box
    #2 wiper motor clearnace
    #3 ac and alt hits subframe
    #4 oil filter hits starter
    i dont run heat or ac in my car so #1 is not an issue for me
    my wipers dont work so i have no problem pulling out the motor
    the ac compressor i will just remove, but the alt mount is part of the front engine cover.
    can the alt be moved or custom brackets fabbed
    oil filter whats the options to move it besides a remote mount.
    does anyone know the tq converter bolt pattern on the lq1 flex plate
    im looking into this to do a swap into my f-body turbocharged of course
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
  • project89
    • Sep 2008
    • 247
    so noone knows about moving the alt mounts or has the dimensions on the flex plate for this motor??
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      how does the alt and ac hit the subframe? they are mounted pretty high, especially the alt.
      if you have the old style starter, it always hits the oil filter if you try to remove it. but once you get it all put together i do not see that as a problem.
      • project89
        • Sep 2008
        • 247
        hmm i was told they are mounted low, guy on thirdgen stared swaping one in.
        are the accesorys mounted differently depending on the year or what the motor came out of?
        • project89
          • Sep 2008
          • 247
          found a low milage 96 dohc motor for 400 bucks complete with harness for 450 bucks.
          good deal? or should i hold out
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            wow if i had the $$$ and a car to put it in, yeah id take it. sorry about the above, i didn't know they mounted so low. could you engineer a mount spacer or does hood clearence become a problem then?
            • project89
              • Sep 2008
              • 247
              need to do custom mounts anyway, so i wont know till i actually have the motor in my hands.
              im deff ditching the ac compressor so thats no worry, but i do have to have an alt, though im sure it wont be that hard to move.i was just curious if anyone has done ti before.
              when it comes down to it i want the motor setback as far and low as possible
              one other ? are the heads the samefrom side to side, i seeone side has a nice cover buit the other side is kinda ugly. id liek to get 2 of the front covers to use if they will bolt on
              heres a pic of the swap the one guy started. iirc he said he droped it in on the factory mounts.
              • 91LQ1Lumina
                Humm, Quad Cam Goodness!!
                • Feb 2008
                • 136
                This motor was built by Steven Snyder, he is on the forums from time to and I think he has one of the best looking LQ1's around. Notice he has used two back covers.
                (Hope you don't mind me using your photos Steven)
                • project89
                  • Sep 2008
                  • 247
                  dam that looks really good,anyways i was up at my friends shop today and he knows somone who used to specialize in 3.4 dohc swaps into fireos and builds custom manifolds and some other parts for these motors.
                  so sometime this week im gonna go over there with my friend and talk to the guy, and see what i can pickup for my build
                  • Jore Knight
                    • Dec 2008
                    • 6
                    keep updates if youre doinf this, btw are you going to use an auto or a t5 for this swap?
                    • project89
                      • Sep 2008
                      • 247
                      so far it looks like im going for it,unles ssomone can give me any good reason to not use this motor.
                      i would love to drop a t5 in the car buttttt it will never live up at the drag strip,i have a hard enough time keeping built 700r4's alive.
                      that and since i mostly drag race the car the auto with high stall will be alot faster then the t5 would be even if it would hold up
                      • gpchris
                        • Feb 2007
                        • 477
                        why not mod the subframe to clear the alt?
                        • Jore Knight
                          • Dec 2008
                          • 6
                          if you can make that work out your gonna have a crazy car
                          • project89
                            • Sep 2008
                            • 247
                            its a good possibility i can. but until i get the motor set into the engine bay i wont know what will be easier to do.
                            the one guy who is attempting this swap was saying if i move the motor foward a lil bit everything will clear.
                            but this then means trans x member and some other mods need to be done
                            • Jore Knight
                              • Dec 2008
                              • 6
                              couldn't you just modify the tranny x member and the motor mounts so that everything moves an inch fordward?
