Sparksplugs wires
  • HayesPerformance
    • 783
    I realized now I did not read your reply correctly in regards to the wires.
    Sorry about that!
    What you mentioned about the hole in the coil is true,
    ANY coil that gets shorted out is VERY dangerous!
    They can even blow sending melted plastic all over if there very high voltage.
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    • Identity Crisis
      Lost at Birth
      • Jul 2006
      • 295
      Well I always find people who are ready to put down the quality of a product are easier to find then those promoting it.
      I hereby promote MSD. I have had the coils on my car for a year now. Temp Ranges of -48deg Celsius to +38deg C (not under hood). I have pressure washed my engine 5 times and mine still work fantastic. As a matter of fact I may just remove then and test them to see how they are working with my Multi Meter.
      I stand behind MSD products.
      I dont know what this means but "ASS HATS" is funny
      • Dave96z34
        • Apr 2005
        • 624
        I stand behind MSD products. Just not the 2 tower coil. Think it needs more R&D. My second coil died after 30K miles at about 2 years old. My advice to you is keep a spare coil in your car and a multimeter.
        • cutlass supreme FE3
          • Nov 2008
          • 225
          Originally posted by Dave96z34 View Post
          What? An independent ground for each spark plugs? There is no reason at all to add ground to every plug.
          Sorry made a bobo. They were not magnecore but Nology
          sorry for the confusion i might have caused.
          • HayesPerformance
            • 783
            Thats just to create a ground loop for each wire to lower Electro Magnetic Interference (EMI), but with most wires, you don't get any EMI to the other electronics and radio anyway. Your fine if you use a larger dia. wire.
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
            • Identity Crisis
              Lost at Birth
              • Jul 2006
              • 295
              #21
              Nology makes wires for the 3.4DOHC? I never knew.
              • Dave96z34
                • Apr 2005
                • 624
                #22
                I looked its just for the 01+ 3400 not the lq1.
                • 91LQ1Lumina
                  Humm, Quad Cam Goodness!!
                  • Feb 2008
                  • 136
                  #23
                  Those are pretty nice looking wires, how much did they set you back? If I may ask that is.
                  • Identity Crisis
                    Lost at Birth
                    • Jul 2006
                    • 295
                    #24
                    cutlass supreme FE3. Are those available for the 3.4DOHC? Them der Nology ones der.
