if you used the lq1 pistons & the 2.8 rods/crank-what CR would that be?
what cr would a 2.8 crank'd lq1 have?
Have you still not figured out how to use the site's CR calculator??
You would end up with a 3.0L with a CR of 8.06:1, if you used a 91-95 DOHC as your base.-Brad-
I thought about doing this once. If you really wanted to go gung ho you can still get billet 2.8 cranks from the off-road racing days. Problem is the 2.8 crank is externally balanced and the 3.1 and 3.4 cranks are internally balanced, so you will have to account for that. I would use a longer rod to get the compression back and have a sweet rod ratio and a motor that could wind up to 9K if you could figure out how to oil it at those speeds.Last edited by OldSkoolGP; 05-01-2009, 11:16 PM.I may own a GTO now, but I'm still a 60V6er at heart.
also no i havent figured out how to use the cr cal because as far as i can tell its just a text box with a few options.
