My FWI w/ PICS
  • mrl390
    • Jan 2008
    • 132
    My FWI w/ PICS
    Well I finally put in my FWI ive been working on for the last few days. Here are some pics. And let me tell you its LOUD!
    -Matt
    Great job!!!!
    • mrl390
      • Jan 2008
      • 132
      Thank you
      -Matt
      • gpchris
        • Feb 2007
        • 477
        Looks nice, bet it sounds great at WOT
        • mrl390
          • Jan 2008
          • 132
          Oh it does.
          -Matt
          • hok666
            • Jun 2006
            • 120
            Is it completely custom?
            • mrl390
              • Jan 2008
              • 132
              Yes its completely custom.
              -Matt
              • hok666
                • Jun 2006
                • 120
                Ok, What type of materials did you use? Ive never seen clamps like those before, there nice, I want some.
                • jmgtp
                  • 1219
                  How big/what kind is the filter on the other side?
                  The mouth of my TB is 4" (the plate iteself is about 3" - it is 75mm)and I currently have a plumbing adapter that reduces it to 3" with to mate it to a 3" tube and cone filter. Other than being a WAI this also creates a low pressure area right before the TB which is prolly detrimental. Ideally I want a 4" filter/tube leading to the 4" TB mouth, which tapers down to 3" - creating a high pressure area, less turbulence and hopefully better flow.
                  I've been thinking about making a CAI, the battery is already in the trunk so I have the space, but I'd want to use a 4" tube and filter to match the mouth of my TB. I'm concerned about what size filter I can reasonably fit in there. THe only thing I can think of is the 'mushroom' kind that is basically a foam filter with a plastic undercarriage to retain its shape. A regular 'cone' filter will be too tall to fit between the inner/outer fender area.
                  1994 Corvette
                  LT1/ZF6
                  2006 Dodge Dakota 4x4
                  3.7/42RLE
                  • mrl390
                    • Jan 2008
                    • 132
                    My filter is an APC short cone filter. Same structure as the normal sized cone filters, but shorter. It is a 3"-4" inlet with rubber rings that adjust the size. It is short enough that it doesnt have to turn down to fit in the fender. The couplers are APC 3" rubber couplers that came with the clamps. I got both the filter and the couplers at Advance auto. 25 bucks for the filter and 13 bucks for each coupler. I just used 3" steel tubing for the extention and painted it black. I made my own fender block off with a piece of the 3" tubing and some sheet metal.
                    -Matt
                    • Sloick
                      • Jun 2009
                      • 10
                      where did that upper motor mount come from. my lumina has one.
                      2000 Buick Regal GS (FAST)
                      1993 Lumina Z34 (NOT FAST)
                      • mrl390
                        • Jan 2008
                        • 132
                        The mount has the name of the company written right on it, clear as day.
                        -Matt
                        • Sloick
                          • Jun 2009
                          • 10
                          hey thanks. how long ago?
                          • mrl390
                            • Jan 2008
                            • 132
                            Im not sure how long ago I got it. I got it used from a member on this forum. Maybe 9-10 months ago maybe longer.
                            -Matt
