I plan to run the 95 ECM with 50# injectors, LS1 MAF, Perfect Power SMT5 piggy-back to control the MAF frequency and ignition timing
ct26 part 2
Do you know if the Perfect Power piggybacks will work on the 95 ECU and crank trigger setups for ignition timing and fuel? I've been trying to figure this out for a bit. Thanks!Originally posted by pontiacjeffThe T4 .68 turbine housing is your problem. Also, the o-c housings do not spool up like the tangential housings. Hopefully it's an O-trim turbine wheel (measures just over 2.25" when looking into the outlet side). If it's a P-trim (just over 2.5"), that's what I use in my 6.6L V-8 turbo, and that's way too big. Really, you need a T3 .63 or .82 A/R depending on how fast you want it to boost.
How do you control fuel??? (Beware the FMU. Stock injectors shut off at about 70psi.) What size injectors? MAP? MAF?
I plan to run the 95 ECM with 50# injectors, LS1 MAF, Perfect Power SMT5 piggy-back to control the MAF frequency and ignition timing.
I should finish it this month (or next).
325 whp 350 lb-ft
The Perfect Power will work on multiple tooth, missing tooth, one tooth signals. I have not used it to run DIS yet. I did use it successfully to run the ESC on a 2.8 Fiero.
I expect to use the crank signal as a base reference. Not sure how it will work yet. I'd like to use the SMT-6, but I don't have one. I do have a -5.
I don't know how it's going to run with the 50# injectors, but the PP can modify the MAF signal to almost no frequency output. The injectors might be real lazy down there... I can always change the injectors if it's a problem. It seems others run them and get away with it.Jeff Ianitello
Engineered Performance
Atlanta, GA.
