92 z34 ecm wiring diagram?
  • savannaz34
    • Jun 2008
    • 72
    im lost,ive got spark,fuel pressure,power at the injectors,changed the knock,crank,and tps sensors,changed the icm,sparkplugs,ect,ect,ect.
    my car wont start,i just had primed and ready for paint,now this.
    any ideas?it seems like something is telling the computer to shut off the fuel,and i have no idea what it is
    thanx guys
    does your car use VATS(or more accurately, PASSKEY II)?
    • 55trucker
      • 213
      Hmmmmm.......have you pulled out the plugs to verify that they are possibly gasoline soaked and are sparking?...If you've got fuel, have spark to each cylinder..then do you have air?...Is the IAC motor closed off preventing any air from getting to the cylinders?...and have you done a compression test just to verify that there is compression.
      91 LQ1 GP GT
      • savannaz34
        • Jun 2008
        • 72
        ya,ive got compresion,ive got fuel,spark,ect. but something seems to be telling the ecm to kill fuel delivery, sometimes it starts up fine then dies,it wil stay running some times for as long as i want it to,other times it will only stay running for a second,and most of the time it wont even sart right up,it just pops,i have no idea what is going on with this motor.ive ask a couple of mechanics and they all say the same things,this sensor or that sensor,blah,blah,blah.all sensors are fine or replaced,tested them all many times,
        i was hoping someone has a diagram of the injector harness?
        im thinking maybe i have an ijector wire crossed some where.so if i could get the exact location at ecm,i could test the wires individually.
        sorry for the long confusing list of info,but im ready to scrap the car
          http://60degreev6.com/forum/attachme...5&d=1239503526
          this should work for you.
          • Smittro
            • Aug 2009
            • 94
            The 92 z34 TDC engine uses a speed density program. It fires three injectors @ a time, with the assumption that one valve will be open @ the time of the pulse. It's possible you have something crossed @ the injectors. However it sounds almost like a timing issue. May possibly have vacuum lines to the canster purge soleniod crossed, or maybe vacume lines crossed @ the MAP sensor as well. I need some more info plz. Like what are your mods, and what lead to this issue? Have you had the harness removed for some reason?
              according to some brainstroming between some of the creative minds here, the PCM doesn't necessarily do 3 at a time, its more likely that all are fired at the same time, with multiple pulses per revoultion.
              • savannaz34
                • Jun 2008
                • 72
                i bought the car like this,(all it needs is a batery)yeah right.i only paid 400 dollars for it.as for mods,none.it does have cherry bomb mufflers,a custom hot air intake,with k&n cone filter,and thats about it,its funny you mentioned the wiring harness,becuase the motor was just put into it a year ago,so yes the harness was removed,iwe had the car running great yesterday for about an hour,then shut it off,now wont start.
                while it was running,i unpluged the MAP sensor,and the car would die instantly,did this several times,my low coolant light stays on consantly(running or not)rad is right full.my compression is 150-160 psi between all cylinders(four second cranking of starter each time)i took the plenum off lastnight to check regulator vacum line,its fine.fuel injector harnes wires appear to be in good shape.I DONT KNOW WHAT IS GOING ON,or what more info i could give you guys,im ready to put some oxy/accetalyne into the intake and watch the show
                thanx guys,if you could think of anything plz let me know
                • 55trucker
                  • 213
                  If you can, try to run thru the *No Start* diagnoses....I know it's not as easy if the scanner is on hand...but some of it can be done...
                  91 LQ1 GP GT
