dohc intake without battey relocation
  • Jake91
    • Dec 2008
    • 202
    i found that when you remove the air box there is a nice little 3in gap that runs in front of the fans so if you dont use any larger than 3in pipe you are fine
    step 1 it is pretty strait forward just cut you piping how you want it you cant really mess this up. i decided to use just the stock hose and ad on to it to save time and money so off off the maf a 9 in 80* bend will be perfect and angle it down so the intake is running at an diagonal
    step 2 then you need just about 4 in of strait pipe if you are useing a 9in long filter like me
    and then since the filter will hit the fan you need to ad a 70-90* bend to get it down a bit lower but not have the filter scraping the ground
    end result the easiest intake you have ever built
    I hope you don't bump curbs a lot with the frame or scrape over speed bumps because picking up a squirrel with that would be a mess to clean out of your intake. Neat idea though
    • Jake91
      • Dec 2008
      • 202
      thanks. no i dont ever scrape this car i think i have scaped it 3 times since ive owned it but not the frame. mufflers 2 times and the platic valence
        Yeah, the Z34 has the worse front facia to worry about hitting on stuff than a Cutty. The 91 uses a Bra to hold it together, lol. Then 92 is just fine because I tend to be more careful with it.
        • hok666
          • Jun 2006
          • 120
          I was thinking of doing the same thing thanks for the pics now I have an idea
          • hok666
            • Jun 2006
            • 120
            I was actually going to go with a smaller filter than the one you have, actually might be better so that you dont hit bumps and knock it off
            • Schurkey
              • Apr 2007
              • 339
              Seems to me you're removing a nicely-engineered air intake system to install a disastrous kludge.
              Hey, it's YOUR car.
              Ever seen what happens when a low air intake like that meets up with deeper-than-expected water?
              • Jake91
                • Dec 2008
                • 202
                I live in Arizona. What water? LOL, and I dont drive this car in the rain anyways
                • Jake91
                  • Dec 2008
                  • 202
                  just so you know i had the car off road the other day and nothing hit it
                  • hok666
                    • Jun 2006
                    • 120
                    cool ^ ill probably be doing the same this spring or at least a CAI in the summer time and WAI in the winter
                    • sarienbarry
                      • Jan 2010
                      • 4
                      Ok I've searched and searched and had no luck finding what I need to know! I know that you need to have a fuse from your alternator to your battery when relocating to trunk. Well all that I have seen called for 150 slow blow fuse. I have upgraded my alternator from the 130 to a 150 amp. So will the 150 fuse still work fine or do I need to step up a size on the fuse and if so what size?
                      cheap r4 ds
                      • GTP091
                        • Jun 2005
                        • 232
                        Start a new thread in the right section
